I now the devices work b/c I have tried them on many other tvs. I have tried using other cords. I have tried fliping the cord ends to see if it is a directional issue. I have tried all 3 of my HDMI ports and none of them work. My cable coax and s video cables work but none of the HDMI work. I have tried holding down the power button per Roku but no help. The BluRay player has been updated with the newest update and still no screen. The Roku you can see all of the apps and go into the menu but once you play the video you recieve a purple screen and an error of "HDCP unauthorised. Content disabled."
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
The quick fit is put a HDMI-EDID emulator (with HDCP) between your TV HDMI port and Apple TV or Roku Player. Basically, the emulator just feed the Apple TV or Roku player with correct EDID and HDCP key, so the Apple TV or Roku player will think that you have a HDCP compliant HDMI TV.
SOURCE: When i try to play a Blue Ray DVD, the LG LCD tv
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
SOURCE: lg 42pc1dv have just purchased a lg bluray player
hi. i have the same problem with my sky HD box and the same lg tv as you,
did you solve the no sound through HDMI.
SOURCE: Hello, my LG Bluray player
This is an known issue for LG streaming video from USB devices, it also happens to LG HDTV's for unknown reasons. No permanent fix yet but normally rewinding the movie and fast forwarding again to the same spot fixes it but not permanently as it might re-occur anytime.l
Testimonial: "ty"
SOURCE: I just hooked up a
Hello
Connections with DVD-TV is of main concern. For HDCP connections, very high quality cables [like Monster Cables] should be used. There is special type of cables to connect to HDCP. The length, wire guage, shield of these cables are of special types, and signal loss will be negligable. Connect the TV with DVD with good quality cable packed specially for HDCP. This will solve the problem. OK.
SOURCE: TV: LG 42LE59000. BLU
You might need to replace the SSB signal Board.
Look on website shopjimmy,com for replacement board.
