A
Art Carey Posted on Jan 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Soundlogic XT 5 in 1 wireless headphones will not receive audio from tv; only gets radio stations.
Reset, unplugging and replugging, removing and replacing batteries, turning off and turning back on.
zeceten
Level 2:
Sergeant:
  • Expert 399 Answers
  • Posted on Jan 04, 2015
zeceten
Expert
Level 2:
Sergeant:
Answers
399
Questions
0
Helped
108484
Points
675
Did you connect the base/transmitter piece to the AUDIO OUT jacks on the back of the TV ? The radio you are listening to is the built-in FM radio/tuner. You need to connect the transmitter to an audio source (TV, PC, CD/DVD player, etc.) to receive sound from that source.
1helpful
I'm looking for the manual for a SoundLogic XT AWS-12/2970R Bluetooth splash proof speaker with FM radio. Specifically, I need the instructions for programming stations into the FM radio receiver.
I didn't see a manual online in searches.
It might be able to discover something from questions on the web sites sellling it, or ask your specific question and see if it is answered.
Example:
https://www.homedepot.com/p/SoundLogic-Bluetooth-Shower-Speaker-with-FM-Radio-and-Carabiner-in-Red-AWS-12-2970R/206079715
Quoted from llink above:
How to use FM Radio in this device This question is from Bluetooth Shower Speaker with FM Radio and Carabiner in Black
November 28, 2015
How do I use the FM Radio in this device. The device description says FM Radio but there is no mention of how to use it.
Answer this Question Answers (5)
December 29, 2015
If you push the middle button it will switch from Bluetooth mode to radio. The first time I used mine it immediately searched through all the radio stations it could detect and store that information. Kind of like when you plug in a new TV. Once that scan is done it will play the lowest numbered station, you then use the buttons on the left or right to advance to the station you want. Don't press middle button again or it will go to Bluetooth. Good Luck
December 5, 2015
Turn on the device with the power button and then press and hold the "play/pause" button down until you hear the radio. Press and hold the back and forward button to control the volume and press the back and forward button with a quick release to switch the radio channels.
December 28, 2016
Hold down the play/pause button until the radio turns on. First time you use it, it takes a couple of minutes to program the channels then use arrows keys to go through the programmed channels.
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
2helpful
No audio from TV through Wireless Headphone
Unfortunately, this product has a reputation for unreliable operation. Many Amazon users report that they can't get it to work with their TVs. To isolate the problem, try plugging a good set of wired headphones into your television; if you hear nothing, then the TV is at fault. Otherwise, try plugging a different, known-good adapter cable into the TV. If you still don't get sound, then the Genica is broken.
How do you connect the Sennheister RS120 Wireless Headphones to Samsung Smark TV?
You should have either a digital audio out port in the back of your tv or color coded analog out ports. Are you sure you have the cables plugged into the appropriate ports? I made the same mistake when hooking mine up, sometimes the print identifying the ports is very small. Also, since the headphones are wireless you may be receiving some kind of interference from somewhere. If you live in an apartment complex or next to a power substation that could be an issue.
Hello, I get no "audio out" from my TV and I need this to be able to hook up my wireless headphones. Thanks for any help! Kendrick
Go to the menu reset the audio setting back to factory.Unplug,replug after a few mins.Should work after that asuming ur signal tuner board have no problem.Check ur Wireless head phone with other
devices make sure that's not the cause.
Tuning in to TV with wireless headphones
I need more info on this. What type of tuner and receiver? Is the tuner plugged into the headphone jack on the tv? If you have a tuner for tv that tunes in channels 2,3,5,12,25,60 etc that would be an older tuner that used the older NTSC standard. Tv stations now broadcast using ATSC, channel 4,1, 4.2 etc.
 Grubhead
Grubhead
SmartAviator
SmartAviator
