I was told my old heater was needing an expensive gas regulator, so i bought a new heater, ( 75k ),only to find out I had no gas flow, to the heater.
Check on the local codes governing gas piping, but it would be my suggestion to consider abandoning the existing line IF you are sure there is a compromise to its integrity allowing water to enter. I would think if water ENTERS...then GAS has to be able to excape. It'd be a lot of condensation that's required to either just block the line or freeze and block the line. If it freezes due to lack of depth, it's going to rupture anyway sooner or later necessitating replacement.
At the above ground location before where it goes subterranean, (after checking the codes), consider installing the appropriate brass fittings to then allow a new underground copper line to be installed by attaching by means of an iron pipe to flare adapter in the appropriate size. Then utilize type L soft roll copper to lay in the new trench to the garage and tie it into the existing line inside the wall. Type L is the thick walled soft tubing and can be used in many locations for gas, whereas Type M soft copper tubing is thin walled tubing for use with water and not gases. Your area may not allow it. That's what building inspectors are for.
Before proceeding, MAKE SURE your line is in fact the problem then double check with a local authority whether or not copper materials are recommended along with brass fittings for the connections. IF the original and suspected problematic gas line is for sure GALVANIZED it is not in any way approved for use with natural gas. It is probably black iron pipe.
