I have a Motorola RAZR V3 phone (very old phone, I know) that has been dropped in water. I disassembled it wanting to see what the problem was, and, using a multimeter, I figured out that the pins 1,2,3 from the charging port are shorted out. The port looks good so I figured out that there must be a defective circuit somewhere, but i can't figure it out... Could you guys help?
Luca
Some people have had success putting their phone in a bag of rice for several days with battery out without turning it on. For some this works but it is usually only temporary. Plan on getting a new phone and transferring your info even if you get it to work as your days are likely numbered. Wish I had better news but water and electronics don't mix.
Mark
Motorola Support
If it was dropped in Salt water or polluted water, you would need to trash it it away as the salt corrosion will damage everything beyond repair. If the radio had the battery taken out and was immediately washed in distilled water or purified water from a supermarket and then dried in a warm place it usually works OK when dried.
If you want to see if the phone works I suggest you try to get a charged battery and put it in and see if the phone works. If it doesn't phone is probably beyond repair. As for the shorts on the USB charger socket it could be that the on board mini USB socket was mechanically forced / twisted and the pins are shorted out.
If the phone was on when it was dropped in the water it probably will never work because the circuits inside will have been compromised. If the phone was off, remove the battery and it can be put in an oven set to 'warm' and left for several hours. This dries out the circuits an sometimes lets the phone work. Usually the phone gets damaged when it is dropped in water.
