You need something like a razor blade to crack open the seam.
Most US models cant replace the battery or even have a place for a sd card.
The best way to transfer photos to a storage is use the feature in google+ (plus) to transfer from phone to another device that also has a removable storage,as well as google+ installed on it.
Then transfer your photos onto other device storage card..
please rate my answer,Gary
SOURCE: i want to unlock my optus sky vega 4g lte mobile phone
I have a mobile of SKY company model no is IMA820L.MY phones IMEI no is 359245042302784.As 3G network is not working please tell me the unlocking process.Thank you
SOURCE: my lg viper 4g lte wont boot completely
if you wont mind losing your data that are not backup... you can simply perform a hard reset to factory settings.
1. remove the battery
2. re-instert the battery
3. hold VolumeDown button then press the power button
Do not release the volumedown key til u get to recovery mode
Now that you are in recovery mode,
first try WIPING CACHE
and then reboot your phone.
if the problem persist, then repeat step1-3 again
this time, select WIPE DATA FACTORY RESET
if wiping cache solves it, then your data are intact
WIPING DATA FACTORY RESET wil return ur phone to new without losing any unlocking feautures.
i'm McKennie
www.iswaltech.com
www.iswalhost.com
SOURCE: this is a bald Android smartphone 4G LTE source 4G
I don't think its anything serious but first try to update the phone go to settings-Device-check for update if you hit on update after performing update check and the phone is up to date I suggest you do a factory reset if does not resolve you need to reload the O.S contact a phone doctor for reload.
SOURCE: How to use a verizon 4G LTE phne with another carrier
You probably cannot. Most phones need to be unlocked, which is a whole different can of worms. And probably this one will not work in the 4G mode with another carrier.
