Question about Dell PowerEdge 840 (becwmk1_2) Server
Hi i wanted to upgrade my poweredge 840 and use it for gaming, but it wont let me disable on board gpu. screens just go black, when invidia pluged in. can you help? or is there a MSI motherboard with
I have already tried looking for a bios switch but no luck. and PCI GPU doesn't take over after boot.
    Sergeant:
    Novelist:
  • 143 Answers
The system won't run your everyday PCIe GPU card. It's just not engineered to use them. (There are several reasons why but I'm not going into them. It's purposeful on their part is all you really want to know here.)
Dell is notorious for making boards that fit ONLY their cases and vice versa. It's likely that the server case on this model - as with nearly every model of theirs I've dealt with - is NOT going to accept an ATX board.
It really is a dead issue. Cut your losses: toss in a few NICs and install a firewall OS and have some fun. Learn something. I recommend IPFire - especially if you're just starting here - which, no offense, seems to be the case.
(^_^)
Posted on Jun 14, 2015
  • Dell Master
  • 4,134 Answers
The problem that you are having is that the unit you are trying to upgrade is a SERVER, and not a desktop PC. There are notable differences in how servers are built. One is that they are not all that concerned with graphics and graphics performance, since they normally operate "in the dark" and are often accessed remotely. I did some research on the Dell site and saw a comment about your problem in one of their forums. I provide the link below. It should be informative.
Graphic Card not working in Dell Power Edge 840 Server
Posted on Jan 03, 2015
  • amboy36069 Jan 06, 2015
    Thanks terry. I had came to the same conclusion. Do you know what board would fit it? I would like to make it to a PC and not a server. I prefer a MSI board in it.
SOURCE:
Orange blinking light on 840 PowerEdge
Take all 84 of your servers to a service outlet.
Nov 16, 2012 | Dell Pallet Of 48 Poweredge 840 Intel Xeon...
Why red light blinking on dell poweredge 840
Check your power supply or the power supply source (outlet or UPS unit) as well as the power cord. Your system power source is not at the correct amp, voltage and may need replacing.
Good Luck.
C2Solutions
Feb 14, 2012 | Dell PowerEdge 840 (becwmk1_2) Server
The sticker says my video card has 1 gb ddr2. but when i open dxdiag it says 251mb. can help me? i want to play games
Hi johnpaulanq3,
1. Go to your bios by pressing delete or F2 key. 2. Go to Chipset tab. 3. Go to North Bridge enter, IGD currently Enabled press enter and select Disabled. 4. Press F10 to Save and Exit keeping your changes.
The set up above is a sample BIOS settings for Biostar H55 mother board,used as a reference to show how to disable the integrated graphics card. it might be a conflict to your 1GB DDR2 GPU.
additional Initiate Graphic Adapter This item allows you to select which graphics controller to use as the primary boot device. Options: PEG/PCI (Default) / IGD / PCI/IGD / PCI/PEG / PEG/IGD
as you can see most mother boards now a days can work well with integrated GPU and discrete GPU so it's up to you if you want to disable the IGD or same.
If you want to verify the running GPU's right click on My Computer, Properties, Device Manager, Click Display Drivers and see what GPU's are running.
Hopefully this information helps.
Willing to help if problem persist, just give more details or specifications.
Thank you for using FixYa.
Aug 21, 2011 | Acer Computers & Internet
Dell Poweredge 840 shutdown automatically
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | Dell PowerEdge 840 (becwmk1_2) Server
I bought a game the secret of margrave manor when i install it i just get a black screen and nothing else please could you tell me why this is
your machine is not powerfull enouft to run the game maibe you can try to upgrade the tree main compunets that will help improve the performance from your pc upgrade memory / upgrade cpu computer processor unit or the gpu grafics processor unit thanks
Oct 10, 2009 | Avanquest Computers & Internet
Microsoft Flight Sim X Black Screen
there may be a power issue with this card. make sure your power supply can handle the cards demands. also. if your using vista, you may want to switch to xp. i would update my direct x drivers as well.
Feb 02, 2009 | Microsoft Flight Simulator X for Windows
Little black flashing dots appear on my tv screen wen playing 360
does it look like the is a checkerboard pattern on the screen aswel?
Jan 05, 2009 | Microsoft Xbox 360 Console
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Dell PowerEdge 840
reinstall your server it will resolve your porb.
Dec 03, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 840 (becwmk1_2) Server Logo
166 people viewed this question
Ekse
Clive
Clive
