Question about Polycom Computers & Internet
How do I reset the admin password to default?
There should be a keypress combo to use during boot and then use the MAC address of the phone as the password. I have this procedure for older Soundpoint models but cannot find anything on the VVX310 that doesn't require you to know the existing admin password.
2 Suggested Answers
SOURCE:
  • 82 Answers
SOURCE: Purchased refurbished phones and they do not have
The factory Admin info is Polycom for the user and 456 for the password. If the password has been changed, you can do a factory reset by holding down 4 keys until it restarts. The four keys are * 4 6 8.
Posted on Jun 16, 2011
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
This router was previously used by my sister-in-law in manila...then i brought this router in japan...when i want to install it in my computer i cant access on the site that written in the...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Computers & Internet
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
I have a asus wl-600g. i sometimes do a power off, and power on again. two days ago, i did a power off, and i kept it disconnected, since the morning until the afternoon. When i connected it again a few...
Sep 07, 2011 | ASUS WL-600g Wireless Router
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Sep 07, 2011 | Linksys WRT160N Wireless Router
Reset password of DGS3627 from console
Sep 07, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
Forgot my password and cannot reset?
Sep 06, 2011 | Computers & Internet
What is the default password for Polycom Soundpoint IP 320 SIP?
Default Passwords:
To get into the web interface, the default username/password is "Polycom"/"456" (Note that this does not work with Safari 1.2.2.)
To get into the Admin interface on the hard phone, the password is "456". (Prior to v1.3.1, the web interfaces to the phone uses "Polycom"/"SpIp" as the username/password.)
The "user password" (not used much) defaults to "123".
To reset a lost admin password to default: at phone boot, during the 5 second countdown, push/hold 468* on the phone. Enter the phone's MAC address as the password. This will reset network info but keep peers loaded. Tested on Soundpoint IP 650.
Dec 22, 2009 | Polycom SoundPoint IP 320 SIP IP Phone
Reset password
Plug the phone in and allow it to boot up. Once the home screen is displayed, press and hold the 4, 6, 8, and * keys for about three seconds, or until you hear an audio alert and the phone asks you for a password. Enter 456 (default Admin password) and the phone will default itself. If the password has been changed, and 456 does not work, enter the MAC address of the phone as the password. Entering the MAC address of the phone will only reset the Admin password to the default, so it will probably be necessary to repeat this procedure, entering 456 the second time, to factory default the phone.
Dec 04, 2009 | Polycom SoundPoint IP 550 IP Phone
Computers & Internet Logo
69 people viewed this question
Top Polycom Computers & Internet Experts
N8nNc
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
