Bunn NHB Coffee Maker Logo
D
Donald Posted on Jan 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove the water reservoir, on Bunn NHBX-B. It seems to be sealed to the metallic part it sits on.
mbarre
Level 3:
  • Master 937 Answers
  • Posted on Jan 02, 2015
mbarre
Master
Level 3:
Answers
937
Questions
Helped
311200
Points
5626
Here is the manual for your unit:
Bunn NHBX Use And Care Manual
The reservoir is not removable.
1helpful
How do I stop water leak
If you're talking about the model shown in your picture, the leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
How to fix a leak on a bunn NHBX coffee maker
Bunn nhbx leaks water
Jun 30, 2014 • Bunn NHBX
How do I know how much water is in the reservoir tank?
You don't. If you pour water in and it dispenses then it is full.
Jan 02, 2013 • Bunn NHBX
The inside of my Bunn NHBX-B is full of gritt and grime. How can I get inside to clean it?
The tank is sealed, however, you can clean it easily by pouring 1 quart of white vinegar into the machine with it still turned on and full of water. Let the water sit for 2 hours and then flush out with 8-10 decanters of water.
2answers
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
