I can't find Service Pack 3 download for windows 7
If someone need windows key that i suggest you go site www.zescode.com to got. My key got here and after i used is great works. Hope can help you.
Mary can you confirm what your operating system currently is.because the category doesn't match Windows 7. Also if Windows 7 download centre only has service pack 1 it probably does not have service pack 3
http://www.microsoft.com/en-us/download/windows.aspx
http://windows.microsoft.com/en-gb/windows/service-packs-download#sptabs=win81
SOURCE: Is windows XP service pack 3 arrived..
Dear, It is coming soon as a bootable format. then you can install just SP3, no need of SP3 for that.
you can down load SP3 from Microsoft web site free and just run it over SP2.
Hope, it will help you.
Regards,
Rakesh Kumar
Network Support Engineer
SOURCE: Video's won't play on my computer
I think the problem is with the Codec.Different types of video formats require appropriet codec to play.I suggest you to install the require codec to play videos.You can download and install K-Lite Codec Pack, which include all the major video format's codec's.
You can download it from http://www.codecguide.com/download_kl.htm
Please try this solution and if you have any problem then revert back.
Thank you
SOURCE: Need Windows XP Service Pack 3 kstvtune.ax
Got a web camera. Didn't work. Said, I needed "kstvtune.ax" and a couple other small files. Couldn't find them anywhere, or downloadable versions. Listened to a lot of advice on blogs. Nothing worked. Finally, I went to the Microsoft Website and downloaded Service pack 3 AGAIN for Windows XP, from scratch. Takes time to download, even at high speed, but it's worth it. First try my camera worked beautifully. THIS IS THE FREE FIX THAT REALLY WORKS! It will get you all the files you need, which may have been knocked off by virus scans, or whatever caused the lack of files for your web camera. Go do it!
SOURCE: I have download windows xp service pack
hello, you need to install it also after download. when it have installed it should automatically restart your computer. then chech your system in controlpanel if it got installed.
