I have kenmore refrigerator and recently I had the dials on 4 which is the recommended setting but the refregiatir is not cold enough
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
