Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
SOURCE: uniden powermax 5.8 GHz not working
have you tried a hard reset. please leave the phone plugged off from wall power for one night and then try starting.
this may start the phone normally and problem will get solved many times.
thank you
SOURCE: message indicator light on Uniden PowerMax 5.8ghz handset
I'm having the same problem, too. However, the beeping continues and continues. Even when it stops, the light comes back on. Any other thoughts?
Blinded by the light
SOURCE: retrieve messages from uniden 8885-2
As soon as your message starts, enter 0 and your pin (w/in 2 seconds). Then follow prompts. More specifics, see your telephone manual - you can go to www.retrevo.com/support/uniden-tru8885-2
See pg 64-65 and if you need to set pin, pg 25. Be blessed.
SOURCE: uniden powermax 5.8ghz TRU 8865-2 handset seems to crackle.
Most cordless phones are sold advertised with their frequencies, as they are not intended to be changed. If there is a way to change the frequency it would be located in the handbook for the phone that came with the device or for download from the manufacturer's website.
SOURCE: AT WHAT SITE CAN I DOWNLOAD A FREE COPY OF THE
Uniden should have their own site, if not call your local PC repair shop and ask them for the manufacturers site.
