If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
You have a bad driver. Reinstall your screen driver or clear your P ram by holding the letters P and R and the control button when you boot your laptop. Hold them until it chimes and reboots.
CD and DVD drives have a manual release.On the door,look for a small hole.You an usually insert a paper clip in this hole to manually release the latch and open the door.
Try starting up in Safe Mode by holding down the shift key. That will be a start to get you into the System Preferences, find your Power Saver preferences and turn Sleep off.
Hope this helps!
Click on this link. Or copy and paste it into your browser. If I could be of further assistance, let me know. If this solves your issue, please be kind to rate it. Thanks, Joe
You're probably not actually flashing the firmware, but downloading the utility to do so. Follow these steps:
1. Quit all other open applications. Open the MacBook Pro EFI Firmware update which is in your Utilities directory
2. Click Shut Down in the MacBook Pro EFI Firmware Update window and wait for your computer to shut down.
3. Press and hold the power button on your MacBook Pro until the power indicator light flashes repeatedly, then release the power button to begin the update.
A status bar indicates the progress of the update.
Important: Do not interrupt the update.
Your computer restarts automatically when the update is completed and opens the MacBook Pro EFI Firmware Update.
