You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process. You will then be directed through the original start-up process as if you got it out of the box for the first time. If you have a Google account and if you stored your settings to Google, your previously loaded applications and saved contacts should start downloading. This is a factory reset, so everything not saved to Google will be lost.
1. Turn your tablet off. 2. Hold volume up and power button at the same time. 3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
you can't. try a master reset by holding down the volume down button and holding the power button at the same time to reset it. 1. hold volume down button 2.hold power button 3. it will reset 4. fill out your info 5. wait for update 6. dont forget your password anymore
Tablet PLT7223GK6-B ((Solution)) Funtional
1. Power off the Tablet.
2. Press and hold the Volume Down button of the device, then a press and hold the Power button.
3- when you leave proscan logo, you can release the botton
4- leaving snowman Android, Press and hold the Volume up button, then Press and hold the power button.
Until you see the menu.
up / down- escojen the option to make
power button- the selecionan
5- Wipe Data / Factory Reset
6- Reboot System now
Before starting, make sure that the tablet is powered off. Not just in sleep mode. Now press & hold both the UP and DOWN volume buttons at the same time.
You may find it easier to hold the tablet in the landscape position on a
table or on your lap while you hold down both buttons.
Next press and hold the power
button until the tablet buttons light up. It will take a minute to
happen, but when they do immediately let go of the power button ONLY.
Keep holding down both the UP and DOWN volume buttons. You only have a
second to do this other wise the tablet will continue boot up as normal
and you will have to start again from step one.
After a
bit of holding down both volume keys the screen will show the Vizio
logo. Then the logo will change to a TRIANGLE with an exclamation mark.
Now you can let go of the volume buttons.
Tap the home button to pop up the boot recovery menu.
Follow the instructions to reset your tablet. Pressing the up/down
volume buttons allow you to scroll up and down the list. A quick press
on the power button will accept your selection.
Wait for the tablet to come up.
Try visit my blog if you want see video tutorial http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
