We have a new W2361G monitor, it looks as if the page is folde in half on screen. We have a lind down the middle of the screen, how do we get rid of this? The resolution appears darker on the right side than the left side of this line
Have a black running veritcal down the middle of my screen with a white bar on each side..almost looking like a white ribbon going down the middle of the screen. I can see through the white ribbon though
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
To change your monitor's resolution
1.
Right-click the desktop, and then click Properties.
2.
In the Display Properties dialog box, click the Settings tab.
3.
Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4.
Click Apply to have the new resolution take effect.
5.
If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6.
Click OK.
Microsoft Windows XP changes the resolution to the settings you chose.
If I understand the issue, it sounds like the
monitor screen is going out.
But there are a couple of things to try since
being close to a high voltage source or incorrect Resolution setting could
cause something close to that.
Let us start with the Display resolution since
it is the easiest.
Hold down on the Apple in the upper left-hand
corner of your screen.
1. Select System Preferences
2. Click on the Displays icon
3. In the box under Resolutions make
sure a resolution selected has 60 Hz if you are running a Flat Screen (LCD)
Monitor.
If that is not the issue, try moving the Mac to
a different location. (Next room)
If that does not work, try booting the machine
for the install disk, if it looks fine when running from the disk you could
have a corrupt driver. In that case reinstalling the OS should fix it.
Ok none of that works: Take the machine to your
local Apple store for the Genius to look at. He should be able to tell by
looking at it what is up.
Best of luck.
