LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
This LE error happens spasmodically over say last 3 years and I can usually override it by manually setting the cycles.
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Looking at several LG Washer service manuals, the error code LE ( Lock Error) could be any one of several things: a 3 pin connector in the wire harness going to the motor, It could also be the harness itself between the Motor and Circuit Board Controller ( PWB) assembly has been damaged or cut..or the hall sensor used to detect drum speed while it rotates may be defective or the main control board ( PWB) "printed wire board " is defective. Lots to pick from but these are the likely candidates... hope this helps
