This did not come with instructions. It has 3 buttons on the side and looks like you can set date and time, but how??
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: can't set day and date on cote d' azur watch
Actually I can't solve this. My son bought the same watch on a Carnival Cruise and had the same problem. Upun closer inspection with a magnifying glass, it is obvious that the hands on the day and date dials are fake!! They are just attached in the center to the watch face. The other two push knobs on the watch also do nothing at all. So basically a rip off, but at least it was only $20. At least it keeps time for now. As usual, if it seems to good to be true, it almost always is. Sorry about that, but we are in the same club with you.
SOURCE: Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
SOURCE: Looking for instructions on a (UNLISTED watch MDL#1070)
You can get the instruction manual here:
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
