Depending what type of pump you have you can use your finger with the system off and see if you can loosen the clog, if not then you have to take the motor off of the pump to access the impeller, if that is the case you may want to call a professional.
A "quickie" check for this is to fill the pump pot with water. Do not put the lid on. While you turn on the pump, be looking down into the pump pot. The water should be sucked into the pump almost instantly. Any slower and there likely is debris clogging the impeller. In almost all cases the pump will need to be opened to clear out the debris.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Dishwasher not draining issue usually occurs due
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
This issue usually occurs due
Daniel
Hi
Daniel
Hi
Daniel
