Televison & Video Logo
C
Christy Monaghan Posted on Dec 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my nordmende tv look for a rescan every time I switch on
Went through the rescan several times but when I switch off and switch on again it looks for a rescan
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Jan 04, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14993260
Points
237762
Main system control memory IC is faulty. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2helpful
2answers
My Nordmende television blue light below screen continually flashing & no tv screen.
Question edited for clarity, your television is 'Nordmende', not 'Norfmende'.
Time for a new one, but try the power reset first as mentioned here.
The standby light on my nordmende tv keeps flashing
JustAnswer https://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ...
1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
How to fix my nordmende tv as blue light is flashing and ...
Ask Me Fast https://www.askmefast.com > How_to_fix_my_nordm...
Its the power supply board, capacitor(s) have gone. Solder on new or replace board. source: 26" lowry tv red and blue standby light flashing and tv wont turn on?
How do you get back ota TV Channels now missing on a Sceptre TV?
Probably needs updating. Switch it off and on again then run a channel search within the menu system.
1helpful
Why does my tv continually drop antenna tv channels. I have to rescan tv several times a day
Assuming that we talking about digital channel could be couple reasons. First- too small antenna or in wrong location. Usually at evening, night hours there is less interference from cars, running electrical equipment etc reception is better. Far away stations reception is also better at night. Trees, houses etc also affect reception. If you in USA you can use site: antennaweb.org to determine correct antenna and direction to receive channels in your location.
These answers do not fit my question. One day, on three different sets in my home, where I have received NBC for years just quit working. Did NBC quit broadcasting? It is not snowy, etc, it is just no
Ok This is what I found out and hopefully found your solution..
Have you heard of Double Rescan?
The Federal Communication Comission Designed a Process called double rescan.
Double Rescanning erases and thenreprograms the channels in the converter box an digital TVs memory.
To Double Rescan, you will first need to disconnect the antenna from the converter box or antenna.
Then disconnect the converter and or digital tv power supplies from the wall. Wait a minute before plugging them back in. The antenna should still be disconnected.
With the antenna disconnected run the channel scan function on the coverter box or digital tv. When the scan completes you will have completely removed any channel data the converter box or digital tv, had in its memory.
Now it's time to rescan for real.
Do this by reconnecting the antenna to the converter box or digital tv and running the channel scan function again.
Thus the double rescan is born.
If the double rescan doesn't work, then try some tips and tricks to get your converter box up and running..I will have to look up the url again that has the tips and tricks...
If the double rescan doesn't work let me know and I will look up more options..
I really hope this works..
Why does my t.v.not store programmes after digital auto tuning
If you're dioing a rescan, then all it is doing is refreshing the existing channel slot frequencies from the last time it went and found channels. The big retune has moved a lot of channels. You need to do a Factory Default / Shipping Condition / First Time Installation scan. This blanks the TV's channel memory and starts again.
I have a logik tv and have accidentally deleted 2 channels how do I restore them ?
You'll have to go to the menu and rescan for channels again. If you have cable this should be no problem. If you are using an antenna for over-the-air signals, you do potentially run the risk of losing other channels as those signals come and go and are stronger at times than other times. If it happens, you'll just have to rescan again, possibly at a different time of day or day of the week.
Why do I have to rescan my tv several times a day
The main system memory IC to your TV is faulty. It must be replaced with same type and number. It is a skilled work. Seek assistance of any experienced service technician for help.
19helpful
2answers
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
2helpful
2answers
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
