If machine is filling with cold water, problem is cold water inlet jammed open. Either replace it with a new one or swap over the hot water inlet - if there is one - and only connect cold water to machine.
If you choose to swap inlets you only need to switch the two wires from each inlet valve and swap the hoses over so that the cold water is then connected to what used to be the hot valve. Leave the hot water disconnected or turned off. Access is through the top of the machine - undo screws at rear of lid and nudge the whole top backwards to release.
Inlet valves are out of service or malfunctionnign follow the steps .
1. unplug your machine power cord.
2. open the door and also open water supply , if your machine fills the water then 100 % problem is with your inlet valves , replace it , simple
regards
SOURCE: Machine drains and dial turns directly to S after filling with water.
moe thasn likly you have a pressure switch that is either telling the machine its too full and making it drain or its not seeing the switch and so it drains. Another possibility ids the machine is leaking. Pull the lower cover off and make sure there is no water in the bottom. These askos have a float switch down there that will run the drain if the sense water leaking into the lower tray. Last but not least, you could have a bad timer. these timers are covered for 5 years (parts only) from date of installation. The first 4 digits of the serial # will tell yuo when the machine was made the firts 2 are the year and the second 2 are the week of that year (so a serial beginning in 0145 woul;d mean built in the 45th week of 2001 and so on. Good luck!
SOURCE: ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
SOURCE: machine wont stop filling with
Same thing happened to my ASKO W600. Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine. Check it out and replace if necessary.
SOURCE: Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
