Hello my nordictrack E3800 has just stopped working... i put in the key and the displays light up but nothing happens none of the touches are working. i pull the key out and it stops and then put it back in and it all lights up but again nothing happens when i try to start it.
thank-you for any help you can give me
Sometimes when these machines are assembled
a wiring harness gets damaged. If you have a manual, look at the diagram that shows the upright columns where the upper console mounts.
Look for the wiring harness coming out the top or bottom on the diagram. If it is on the right, the take the screws/bolts out of the arm that mounts to the upright and lift it up, just a little to see if the wiring harness is damaged or partly disconnected. If you cant see anything, then it is time to call a tech out to troubleshoot the problem.
Turns on and the trac takes of at high speed then shuts down
Makes one fast rotation and stops
