P
Perry Posted on Dec 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ho do I set up atmos on Onkyo
Steps do you take to set up and/or enable Dolby atmos
  • Official Brand Answer 333 Answers
  • Posted on Sep 16, 2015
 Onkyo USA
Level 0:
Answers
333
Questions
0
Helped
170131
Points
634
HI Perry, I found this article from Dolby to be super helpful, http://www.dolby.com/us/en/guide/home-theater-setup.html, Thanks JT
2 Related Answers
larry james
Larry Stiles
  • 301 Answers
  • Posted on Jul 16, 2009
SOURCE: Onkyo TX-DS555 will not switch to Dolby Digital
regulated voltage to the processor circuit like drop in these onkyo after 8 years. This or a small capacitor fails in this voltage line.
Anonymous
  • 118 Answers
  • Posted on Nov 03, 2009
SOURCE: Dolby digital output
sounds like you are watching cable.
Can veon 2.1 soundbars software be updated
I believe that Dolby Atmos would require a hardware change. Atmos has at least two extra channels. This would mean extra amps installed.
1helpful
Samsung hw-n850 doesn't show Dolby atmos on the display when playing atmos content. any ideas?
Make certain that any Blu-Ray player connected is putting out the right signals. Sometimes they can have the option to "mix" signals for certain TV's. This however will kill the signals needed for Atmos.
1helpful
What setting do I need on my Yamaha AX-V683 to play Dolby Atmos movies I have compatable speaker system, but the AV does not show me if it's playing the sound in Dolby Atmos.
Pressing the info (several times) on the remote will show what mode it is in.
The sound mode for movies is selected by pressing the movie button on the remote.
I have an Onkyo TX-NR737 receiver. I just purchased a Sony UBP X800 UHD blu-ray player. I am having no luck in getting the Dolby Atmos to work. what port should Use?
Have you updated the onkyo firmware as Dolby atmos operation requires it
I use input one on my amp for the Sony
video out hdmi port on Sony to hdmi input one on amp the other hdmi port on the Sony is audio only for non 4k receivers /amps
1helpful
Hi...i cannot get sound out off my atmos speakers
The other part of the equation is your source; which is not mentioned in your question.
Your player must also be able to decode Dolby TrueHD and the audio output on it set to Bitstream.
2answers
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
1helpful
3answers
Dolby digital
Dolby Digital includes several similar technologies, which include Dolby Digital, Dolby Digital EX, Dolby Digital Live, Dolby Digital Surround EX, Dolby Digital Plus, and Dolby TrueHD.
Dolby Digital, or AC-3, is the common version containing up to six discrete channels of sound. The most elaborate mode in common usage involves five channels for normal-range speakers (20 Hz – 20,000 Hz) (right front, center, left front, right rear and left rear) and one channel (20 Hz – 120 Hz allotted audio) for the subwoofer driven low-frequency effects. Mono and stereo modes are also supported. AC-3 supports audio sample-rates up to 48 kHz. Batman Returns was the first film to use Dolby Digital technology when it premiered in theaters in Summer 1992. The Laserdisc version of Clear and Present Danger featured the first Home theater Dolby Digital mix in 1995.
This codec has several aliases, which are different names for the same codec:
* Dolby Digital (promotional name, not accepted by the ATSC)
* DD (an abbreviation of above, often combined with channel count: DD 5.1)
* Dolby Surround AC-3 Digital (second promotional name, as seen on early film releases and on home audio equipment until about 1995/1996)
* Dolby Stereo Digital (first promotional name, as seen on early releases, also seen on True Lies LaserDisc)
* Dolby SR-Digital (when the recording incorporates a Dolby SR-format recording for compatibility)
* SR-D (an abbreviation of above)
* Audio Coding 3 (relates to the bitstream format of Dolby Digital)
* AC-3 (an abbreviation of above)
* Audio Codec 3, Advanced Codec 3, Acoustic Coder 3 (These are backronyms. However, Adaptive Transform Acoustic Coding 3, or ATRAC3, is a separate format developed by Sony)
* ATSC A/52 (name of the standard, current version is A/52 Rev. B)
2answers
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
2answers
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
