Different types of dvd-r 16x speed
Terry,
For copying DVD's you have to violate some laws. And in lots of countries you risk punishment when caught. I assume it is legal in your country and will explain some things. (perhaps not everything)
First, not al DVD players are compatible with DVD's you burn yourself. DVD's pressed in a factory, to have a metal coating, making it highly reflective. When you burn a DVD, a dye will be changed from colour, where the laser burns. The reflectivity is much less. Only the DVD players that have a sticker, with DVD -r DVD +r compatible, can play self made DVD's.
Then there is a special format in a DVD. When you open the DVD on a computer, you see two folders, one is called Audio the second is called Video. For a DVD with a film most of the time the Audio folder is empty. In the video folder you find several files, with extensions .VOB and .IF and more.
If you put a .AVI or some other file in the root, you can play on your computer, not one DVD player cam play it.
There are lots of program's around to copy and burn DVD's, but again if your player is not compatible with the self burned disks, it won;t work.
If you have a blue ray player, It will not play copies of copyright material. Try an older not blue ray player.
You must be sure that the file type you are using is supported by the DVD player and that the disk is finalized in order for the player to see the file system properly.
What file type are you recording the film in?
