Based on what you have explained the flood switch next to the filter board is most likely faulty. If you do not have a service manual for the unit download from this site.
http://www.rvtechlibrary.com/appliances/dishwasher_service.pdf
SOURCE: Fisher Paykel DD603 Problem. Top drawer shows F1
Yup, definately the bottom drawer controller, for some reason you can run a DD603 with no board in the top, so long as you have a board in the bottom, but not the other way around. This is the fault you get, constant F1 from the top drawer. If you are stuck try removing the display cable from the bottom controller, this may help, so long as you leave the chassis harness in.
SOURCE: DD603 F1 error on top
Hi
Error F1 on your fisher & paykel means an overfill
condition. One of the most common causes for an overfill fault is that the
dishwasher cannot pump out the dirty water due to a plugged drain hose. Check
the drain hose if it is clogged. Now remove the bottom drawer from the unit to
inspect the flood switch. Remove the wire harness cover on the underside of the
drawer. With the bottom cover off, unclip the wire harness, fill hose,
and drain hose. Then unclip the linkage at the back of the drawer and lift the
drawer off the slider arms. Now' you'll be able to look at the flood
switch. Note the positions of the wires on the flood switch and remove
them. Then unclip the switch housing from the base panel. The switch housing
contains one switch for each drawer. The switches are wired normally closed
(NC) and each switch has three spade connections, so it's important to note
where the wires went. Now clean the contacts and let it dry. Hope this helps...
Please post back if you need more information.
Daniel
