TV wall mount screws for Dynex 32" TV, which size?
We have a Dynex 32" TV, and a wall mount, but we don't have the screws that affix the TV to the mount. What type of screws are used to mount a Dynex 32" TV on a wall mount, and how many?
no it is already mounted the picture is doubled the convergence needs adjusting how do i do this?no it is already mounted the picture is doubled the convergence needs adjusting how do i do this?
You can't post conmments that contain an email address.
order these. it will have everything you need. if want to spend time buying screw and find out they don.t work and spend you time going back and forth to save a few pennies in the screws, or just order and have it there at one time. you can look to see if there are other vendors with free shipping.
first you neeed to buy a wall mount kit for your size tv, menards or lowes is cheaper than best buy. you can also purchase a box for behind the tv that has a cable and power supply, it mounts in the wall so you see any wires. you must take the tv base off, normally 4 screws and make sure you have studs where you would like to mount the tv
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already. http://s807.photobucket.com/home/budm/allalbums
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too) Apparently, most mounts include only 5mm and larger screws
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
DX32L200NA14
