Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.
SOURCE: best wiring and best sub boxes for my solo x 12"
I did not realise yall used these boomers over there. search the internet I bet you can find every thing yoy want threre. just searrch car stereo
SOURCE: i have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
SOURCE: best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
SOURCE: I have an Audiobahn A8000T amp and 2 12
First of all your ******** shouldn't be running that many watts to two 12" cvr's. I have one in the specially insulated and plastic ported box that kicker made exactly for that sub. I'm running 850 watts to it and the peak on it is only 800, and i cant even turn the amp more than half way up. So pretty much you wanted help trying to figure out what to do, well here it is get another ******* amp with less wattage and a 2 channel amp *******.
