Reloaded mtn service did not work,called mtn told them about the problem they said they will send stuff from there side need to put off my phone remove sim and batry for 5min the problem should be fix still the same
SOURCE: sony ericsson w810i
sir mere mobile insert sim & usb loding problem ha mana karnal center ma 2 time dhikhiya lakin mobile ki problem sahi nahi ha my mobile no s 808 n . call no 9728242457
SOURCE: inactive sim
This is a known design flaw with the w760i - it occurs when the phone requests info from the SIM (building contact list etc.) and the SIM connection is lost. This would happen on any phone but the w760i has a shock protection design issue whereby closing the slide quickly causes the SIM to disconnect. You should be able to replicate the issue by turning the phone on and slamming the slider shut as soon as the phone shows your network name. Leave the phone on for a bit and you will feel the phone buzz and 'Inactive SIM' will display, the phone will then reboot.
SOURCE: i have a w850i and the sceen shows emergency calls
1. It's a common problem with Sony Ericsson W850 phone!
2. It displays the 'Emergency Calls Only' message even the network is available. (Mainly due to the change in the frequency of the signals!)
3. You should try to update the phone OS/Firmware.
4. If it don't helps try to reinstall the OS software!
please rate this advice if it helps...tc! :)
SOURCE: Sony Ericsson K800i says insert sim and only allows emergency calls
i have sonyericsson k800i set it says insert sim on any simcard what is the sollution on my mobile at board side locate me.thank u
