When you say try to convert, you mean reformat from fat32 to NTFS? Depending on the size you may not be able to write it as a NTFS. Also, if you have anything on it you want to save, you need a raw recovery tool Squidoo has a good one.
However, if it won't let you format to anything and keeps reverting to raw, most likley your drive is damaged beyond normal repair.
Hey, friend! Have you extracted all important data out from this RAW USB flash drive before you try to convert it as you wish? Honestly, in your case, you'd better firstly rescue everything original back with the help of RAW file system drive recovery software and then, convert this USB hard disk from RAW to NTFS.
Have not tried to format hard disk from RAW to NTFS without losing data? OK! Here is the article that can help you a lot:
Change RAW to NTFS without losing data
Make drive data backups from now on to avoid drive data loss troubles.
