How do I get the first label to fill the whole page of Avery 5267
Typing the first row of labels hoping it would automatically move to the second row to type. It doesn't. Nor does the first row line up with the size of the return label.
I have the same printer and usually when this happens I am able to flip the lever on the side to put it into auto peel mode and push the feed button on the front and that usually works and makes the light go green. It was explained to me that if the label stock is old it will have a hard time recognizing it. Sometimes I have to pull out the labels and re-insert the labels to get them to work properly. I hope this helps.
You'll need the actual Avery code for this, or at least the correct measurements. Open up Microsoft Word. Go to 'Tools' and find 'Letters and Mailings' in the list. Then off of that is 'Envelopes and Labels'. Click on that one and a box will pop up. If you click on 'Options'. From here you can find the correct label settings by the code which will be on the Avery pack. If you haven't got the code, you can scroll through the lists and highlight options to see the measurements but this will take you a while. Once you chosen your labels, click on ok. Now you can enter your address in the box and print a whole page of the same address or click on 'New Document' and that will give you a page set out correctly for that label sheet.
NORMALLY WHEN YOU GO TO LABEL PAPER IN THE PRINTER PROPERTIES IT GIVES YOU SEVERAL OPTIONS ON WHAT LABEL PAPER CONFIGURATION CLOSELY MATCHES WHAT IM USING. I DONT HAVE ANY OPTIONS AT ALL
Im not really familiar how to make label on Excel but you can try this steps that works on words:
Please follow the steps below to print Business Cards or Labels in Microsoft Word.
1) Click on TOOLS. 2) Click on ENVELOPES AND LABELS. 3) Click on the LABELS tab. 4) Click on OPTIONS. 5) Under PRINTER INFORMATION select LASER AND INKJET. 6) Under product number select the label type that you are using. If you are using Avery labels, select the number that coincides with the number on the Avery package. 7) Click on OK. 8) Click on NEW DOCUMENT. 9) This will give you the layout of the document format on your screen. 10) Type in all the information you need on one label. 11) Once the label is completed, highlight that whole label. 12) Click on EDIT, COPY. 13) Click on the next label. 14) Click on EDIT, PASTE. 15) Paste the information on all labels until page is completed. 16) Print your labels.
With this procedure, you do not need to modify the page setup or printer driver properties.
Hope this help, pls rate as fixya if this helps. Thanks!
In Microsoft Word: Pull down the tools menu and select "Letters and Mailings" and then choose "Envelopes and Labels", choose the labels tab, and select "Avery 5836 - Divider -Mtg. Creator" or manually set a height of 0.5" and a width of 1.75".
In any Word Processing Application: Make a table 10x1, set the row height to 0.5", and then set every other column width to 1.75" and 0.5" respectively with a 0.5" left and right margin, 1.0" bottom margin, and a 2.0" top margin. Add rows until you fill the page.
Hope this was helpful and remember to vote...Thanks
