I tried to insert South Africa when the GPS ask me to select a country,but without any luck,because South Africa is not on the selected list of countries.
SOURCE: SC card
I am not able to look at the map, as it always direct me back to my home. How can I solve the problem ?
SOURCE: Maps
By MS Active sync from computer delete file Mounted Volume/my flash/sony/nav-u.exe (the folder SONY is hidden, you must set show hidden files in your comuter first). And then replace old navi file by exe file of total commander CE version ( download is free on site of developer) .You must rename the totalcmd.exe to nav-u.exe. Now after reboot is allowed everything, including executing any other navi software like tomtom, igo, navigon and many other (multimedia players). The oficial navi (old navigon) by sony is not so good in compare with new navi soft. .. enjoy.
SOURCE: GPS map 60cs does not recognise my unlocked Taiwan City Navigator
I finally downloaded the jetmouse v1.3 key generator and the key it provided worked perfectly. I installed the map on my GPS and now I can drive around Taiwan like a local; always knowing where I am going. Sweeeeeeeeeeeeeeeeeeeeeeetness.
SOURCE: How do I change the country selection on my Magellan GPs system?
I've never crossed the boarder with a GPS unit before but to change countries it's MENU USER OPTIONS REGION I tried to enter a US address but the unit wouldn't take it BUT if you change regions enter lower 48 states then you enter a US address and it will take you there. I just tried it with my 4210 it accepted the address and showed the routing
SOURCE: HAVING PURCHASED A LIMITED LIFETIME UPDATE FOR MY
firstly the reason it cant see corresponding countries is that the garmin units treat each map as seperate , the only way to rectify it is to copy the maps folder from your device to your pc then delete the maps from your device and then download the western europe whole map, doing it this way will give you the space you require plus it will allow you to choose any of the countries in the map
Testimonial: "Thank you. It sounds as though it might work. I'll come back with a result when I've found out how to do it!!"
