Turning off and back on and turning all dials off and back on
Hey guys need some help please
me and my partner have just moved into our first flat and we brought a 2nd hand hot point fffl 1810 fridge freezer
the super cool n freeze are flashing and we cant reset them so we have tried these following
turned both dials to off and pressed n hold the buttons nuffink
turned back on left 1 hour and then turned the freeze one off and pressed both buttons nufink
turned back on for 1 hour and turned the fridge one off and pressed both buttons and nuffink
tooK both panels off on n checked to make sure nufink is blocked n the fan is working
anything else i could try please
Read the MANUAL that comes with it
SOURCE: Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
SOURCE: zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
SOURCE: light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
