I have just rebuilt a honda gx200 generator new rings gaskets etc it will run wwithout the exhaust attached but as soon as i place the exhaust in position it stalls the engine even without screwing it
Its petrol engine and had the piston rings changed as it was burning oil the oil seal on the valve has also been replaced along with gaskets
Re: i have just rebuilt a honda gx200 generator new rings...
-Make sure the exhausted is not clogged.
Good luck
Mai
Testimonial: "thats the first thing i checked i can blow through it and it seems ok so i think i will strip it and check timing etc but thanks for replying"
Hi!
If you have a portable Generator then we can help. :)
Check out our Valve Lash video and see how to pinpoint and fix the problem. https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
If you need more advice or gap measurements we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair. https://www.generatorguru.com/need-help/
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide www.GeneratorGuru.com
are your plugs fouling with oil? then you may have a valve or ring problem, if you are burning the plugs up your fuel is too lean. also, make sure your timing and all with distributer are good
Intake, combustion, exhaust system is supposed to be separate from lubrication system. You have a breakdown somewhere in that separation evidenced by gas smell in oil and oil coming through exhaust. Possibly head gasket or piston ring. Take it back to the folks who rebuilt it and ask them about it.
Double check the tolerances, a loose lock nut on a tappet can make noise. Some times a bad or missing exhaust o-ring can cause a ticking sound, make sure you remove the old exhaust gasket and install a new one.
Did you just have the motor rebuilt by a reputable shop? If so take it back and explain the problem and they should take care of it.
If not you are kinda on your own. What kinda tick? Could be leaking head gasket, base gasket, bad valve guides, incorrect bore, piston, rings. Incorrect ring gap, leaking exhaust gasket, out of time, etc, etc, etc, etc.
You know what they always say about the color of smoke... blue is oil, white is water and black is i don't know lol. Anyhow, if it was just recently rebuilt and you're getting blue smoke then oil is making it into your pistons OR you are burning off oil somewhere when it gets hot. If you are seeing the smoke from the exhaust only, then think about piston rings, head gaskets, all the typical stuff that gets replaced on a rebuild. It's near impossible to say exactly where to look so that's the best I can tell you. I would lean more toward the piston rings.
Good Luck
Sounds like poor engine rebuilt work. The rings probably were not aligned properly. they need to be placed in their proper positions. The valves, guides, weak spings, etc. (Was your cylinder or head machined) Also you could have used incorrect rings-size. Keep looking online for manual guides
