Kenmore Electric Range Model 790.95032505
Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Testimonial: "Thanks for your help! Our broiler and oven quit working when we pulled the range out to clean behind it. When we put it back into place they had stopped working. It was just slid out of place and then back in (no excess force, etc.). I don't see any fuses. Exactly what part do you think would have to be replaced if the fuses have been triggered? The control board? Thanks for the advice."
Notice i prefaced my answer with "Most of the time..." Okay, I did a little more research on your model number, and it appears that your range does NOT have any thermal fuses or cut-off devices. Which means that overheating protection is built into the EOC (Electronic Oven Control), so that is probably what will need to be replaced. But check 1 thing before you do. Use an ohmmeter and measure the resistance of the temperature sensor (temp probe) at room temp. It should be around 1080 to 1100 ohms. (Make sure to turn off power and disconnect the connector to measure it. If it's way off, then that is your problem, instead of the EOC.
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
SOURCE: Maytag CRE9500 electric range has
Hi , Jorland...
I have a CRE9500ADE and has fuses way behind the drawer under the oven,
there is a 15 amp fuse for the clock and controles the way see it.
Hope this helps...
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
