We are currently using the Norstar M7324 phone system and we want to find out how we can increase the number of rings for incoming calls. Right now it will only ring 3 times before going into our AA, but we would like it to ring at least 5 times before going into AA. Any suggestions?
SOURCE: Incoming ringtone length
if you have voice mail, you can set the number of rings before forwarding to voice mail in the administrative options of the voice mail menu itself. Call your voicemail and listen for administrative options. Follow the prompts.
SOURCE: Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
SOURCE: increase rings
This is a programable item in your phone.Check your user manual.If you do not have the manual find your phone on line and look up the user manual.
tk46
SOURCE: changing number of rings
If you would go to your phone and dial intcorm #6041 plus thevoice maik extension number than enter time in 20 for exemple is 5 ring before going to voice mail than hang up.
SOURCE: Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
