Video Game Consoles & Games Logo
Jessica Posted on Dec 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got 2 360 rally car thunder tumblers and when we turn both the cars on one controller will control both cars at the same time. Is there any way to fix this? Cause it's very hard to race each other when your controlling both cars
Anthony Miller
Level 2:
Scholar:
  • Expert 141 Answers
  • Posted on Jan 01, 2015
Anthony Miller
Expert
Level 2:
Scholar:
Answers
141
Questions
0
Helped
38819
Points
303
Most of the store bought RC cars support a few channels and autoselect the channel or they are tied to the controller. Some of the better (hobbist) RC cars have a channel select on the underneath. You could check for that but if these are the 9.99 stocking stuffer specials, you may be out of luck.
5 Related Answers
Anonymous
  • Posted on Aug 11, 2008
SOURCE: Wireless Controller not connecting to console.
Hey guys,
I've had the same problem today. The controller wouldn't connect no matter what. The strange thing was I could still turn the console on using the controller, but afterwards it wouldn't do anything.
Now I think I found a solution, at least for my case. All I did was to remove the HDD (that thing on top of the console) and put it back in. Then I started the console again using the controller and it was instantly connected.:)
Now I just hope it stays this way.;)
Anonymous
  • Posted on Feb 03, 2009
SOURCE: Both Controllers Keep Turning Off During Game Play
My solution of this problem is a bit technical but try and keep up. What I did was to remove the battery thingy so the insidy part was shown. I used my indexfinger and my thumb to pull the 2 springs longer so they would make more preasure at the batteries.
Then I put the batteries back in and havnt had any big problems since.
Im not sure if this solves your problems but its worth a shot since it fixed mine.
If this information was usefull to you please donate some money to charity
Anonymous
  • 19 Answers
  • Posted on Jun 26, 2009
SOURCE: Xbox 360 controller turns off at random, yet has new batteries
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries(or more specifically - bad batteries) - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. I'd recommend a recharge while you play pack. ALWAYS by the official products too. They're much more reliable and aren't prone to this kind of behaviour.
Anonymous
  • 185 Answers
  • Posted on Jan 13, 2010
SOURCE: I have a wireless controller that won't connect
sync the controler to the xbox. there is a small button on the top of the controller next to the plug in for the cord. push that button along with the button next to the reciving eye on the consel. push them both at teh samt time until they stop spinning and start flashing as if they had low batterys.
Anonymous
  • 20 Answers
  • Posted on Apr 08, 2010
SOURCE: Slow Turn
If this is only happening in Halo 3, go to the start-menu and look for profile settings, or check the in-game pause menu ( while playing ) and search for your controller settings. You should see a section that says "Vertical/Horizontal Sensitivity" or something close to that. Change it to a higher setting and you should be able to move your aim/sight faster.
Note: This will not increase how fast you walk/run.
If this does not work, you can attempt to open your controller ( remove batteries first ) and check the joystick for any junk that might be preventing full movement. ( this will void your controller's warranty if it has one )
I bought 2 Thunder tumbler radio control rally cars. They don't come with instructions for how to change the frequency so they can race. Any idea how to do this?
Type the thunder tumbler in Fixya's search. This is two way radios. There are a LOT of posts on your RC trucks. If new, I suggest you return them.
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
2answers
How to change the frequency on the cars, we have 2 that operate at the same time
You can't change their frequency, you have to but a car with them designated, black ones a 47 and red/blue are there 26 or whaterver.
My son received a thunder tumbler remote control stunt truck yesterday, (5/15/11) and it is already broken. My younger son broke the truck where the attena connects, however, I glued that and the truck...
try contacting the company. if the car wheels are broke or dangeling you would need new wheels. if the wheels arent the problem it could b the turning starvos
1helpful
Thunder Tumbler Radio Controlled Rally Car missing antenna
Find out who owns or pays for the website and you'll have a contact number. There are sites that'll give you that information usually for free.
Apr 08, 2009 • Toys
7helpful
6answers
Remote control not working
Actually reached the distributer with an e-mail and within 20 minutes got a reply and a replacement. the Blue Hat Toy Company are trademarks of Distributers MerchSource, in Foothill Ranch, CA.
Nov 20, 2008 • Optics
8answers
Hover Lites RAdio-Controlled Helicopter
tried that said they would send me one , brandon was the reps name, 2 weeks now nothing,
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
