Epson LX-300 Matrix Printer Logo
d
daljeet Singh Posted on Dec 28, 2014
Page is coming without printing
Nothing
superquesito
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 05, 2015
superquesito
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1341
Points
8
Heads clogged. run maintenance on menu +head clean up
please do not do it more then two times .refer to manualhttps://files.support.epson.com/pdf/lx300p/lx300pu1.pdf
2.-no ink: replace
3.-:head gone? time for new printer !
4.-watch tutorials on youtube about trouble shooting
HP 6280 Printer. Not printing. Ran diagnostics form HP software. No issues. Printer an computer are communicating. Can run alignment test and Diagnostic Print Page from computer without issue. ...
Well you definitely have a pc problem and not one of the printer. the printer just prints what it is sent and as you can print the alignment page that takes care of the printer.
You have reinstalled the driver but did you remove the old one first? I bet not. You should download the hp printer removal tool. Run it and after a restart then you can install the driver. Personally i would turn off the auto update feature as hp updates really mess things up.
I reckon after the reinstall the printer will be fine.
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
1helpful
I455 printing totally blank pages
Don't know that particular model but try this.
Sounds like the lines are a bit plugged and are running dry again after the script page.
Never leave an inkjet or deskjet for more than a week or so without using it because the ink wells can dry up.
Take a Q-tip and dip it in alcohol.
Remove the cartridges and soak each hole with a brand new Q-tip.
Let it dry.
You may have to do this a few times before you get results.
Now put in the cartridges.
Go to
Start
Control Panel
printers
Click on your printer
Go to Properties
Go to Maintenace
There should be some kind of thing in there that will allow you to clean and deep clean your cartridges.
I have recovered many "seemingly hopeless" printers this way. A lot of printers that can be rescued end up in e-waste, wasting a lot of money.
Look in the yellow pages and find you local dealer if all else fails. These people are often quite helpful.
My printer says its printing but is only printing out a blank page. why?
Hi fizzy81
Most of the software has a PrintView facility. Select the Printview and see there is something on the Page displayed. If nothing, there is nothing wrong with the printer. It is possible you are trying to print a selection without actually selecting anything. I am assuming that you have ink in the cartridge.
Also, go to another program, or a webpage and try to print from there. This is to find out whether something is wrong with the printer,.
luciana44
3helpful
4100 stops printing mid streem and engins continue to run
Try printing out an error log and seeing if that leads you anywhere.
4answers
Printer is not printing
i got a paper jam and now my printer won't print at all what should i do?
1helpful
Prt scr key
After you press print scr, it won't print to printer, you need to paste it in application such as paint (come with ms windows) and from there you can print it to printer.
the combination key,
try press prn scr only and paste it in paint application.
if it isnot working, try using shift+prn scr.
Print page comes out blank
If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
My hp 1610 all in one
Is the color missing on the calibration page? Maybe some color or cartridge is empty and the printer can not calibrate... Without calibration no work !!!
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
