Subaru 1988 Coupe/Sedan/Wagon/Loyale Condenser Logo
j
john Posted on Dec 27, 2014
Can anyone tell me what size the bolts/nuts are that secure the alternator to the alternator bracket?
I am missint the nut that secures tension on the alternator/alternator belt. I want to replace this bolt and nut, but do not know what size to search. Can anyone give me the size(s)?
marcel1444
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 30, 2014
marcel1444
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1632
Points
11
Probably metric! Ask the Subaru dealer parts dept. They will help!
How to replace the power steering belt on a 4g13
ADJUSTMENT
Excessive belt tension will cause damage to the alternator and water pump pulley bearings, while, on the other hand, loose belt tension will produce slip and premature wear on the belt. Therefore, be sure to adjust the belt tension to the proper level.
To adjust the tension on a drive belt, loosen the adjusting bolt or fixing bolt locknut on the alternator, alternator bracket or tension pulley. Then move the alternator or turn the adjusting bolt to adjust belt tension. Once the desired value is reached, secure the bolt or locknut and recheck tension.
REMOVAL & INSTALLATION
1.5L, 1.6L, 1.8L, 2.0L and 2.4L Engines
Fig. Accessory V-belt routing-Mitsubishi 1.5L, 1.6L, 1.8L, 2.0L and 2.4L engines
Alternator Belt
Fig. Loosen the adjuster lock bolt . . .
Fig. . . . then remove the alternator belt from the engine
  1. Loosen the alternator support nut.
  2. Loosen the adjuster lock bolt.
  3. Rotate the adjuster bolt counter clockwise to release the tension on the belt.
  4. Remove the belt.
To install:
  1. Install the belt on the pulleys.
  2. Rotate the adjuster bolt clockwise until the proper tension is reached.
  3. Tighten the adjuster lock bolt and the alternator support nut.
POWER STEERING BELT
Fig. After the adjusting and fixed bolts are loosened, rotate the pump . . .
Fig. . . . then remove the power steering belt from the engine
  1. Remove the alternator belt as described above.
  2. Loosen the power steering pump adjusting bolts.
  3. Remove the power steering pump fixed bolt on the rear of the bracket.
  4. Rotate the pump toward the engine and remove the belt.
To install:
  2. Rotate the pump until the proper tension is reached.
  3. Tighten the adjusting bolts on the pump.
  4. Tighten the fixed bolt on the rear of the bracket.
  5. Install the alternator belt.
A/C COMPRESSOR BELT
  1. Loosen the tension pulley and remove the belt.
  2. The installation is the reverse of the removal.
3.0L DOHC, 3.0L SOHC Galant, and 3.5L Engines
Fig. Serpentine belt routing-Mitsubishi 3.0L engines (except 1998-00 Galant models)
Fig. Accessory V-belt routing-Mitsubishi 3.5L and 1998-00 3.0L SOHC Galant engines
ALTERNATOR AND A/C COMPRESSOR
  1. Disconnect the negative battery cable.
CAUTION Wait at least 90 seconds after the negative battery cable is disconnected to prevent possible deployment of the air bag.
  1. Raise and safely support the vehicle and remove the front undercover.
  2. Loosen the tension pulley fixing nut and relieve the tension on the belt by turning the adjusting bolt.
  3. Remove the belt.
To install:
  1. Install the belt on the crankshaft and alternator pulleys.
  2. Using the adjusting bolt on the tensioner, tighten the belt to the desired tension.
  3. Tighten the fixing nut to hold the adjustment.
  4. Install the undercover and lower the vehicle to the floor.
  5. Connect the negative battery cable.
POWER STEERING BELT
  1. Raise and safely support the vehicle and remove the undercover.
  2. Remove the alternator and A/C compressor belt.
  3. Lower the vehicle and remove the cruise control pump link assembly.
  4. Place the power steering hose under the oil reservoir.
  5. Loosen the tension pulley fixing bolts and remove the power steering pump drive belt.
To install:
  1. Install the power steering pump drive belt.
  2. Insert an extension bar or equivalent into the opening at the end of the tension pulley bracket and pivot the pulley to apply tension to the belt.
  3. Tighten the fixing bolts.
  4. Raise the vehicle and install the alternator and A/C compressor belt.
  5. Install the undercover and lower the vehicle.
  6. Connect the negative battery cable.
3.0L SOHC Diamante
  2. Loosen the lockbolt on the face of the A/C tensioner pulley.
  3. Turn the adjusting bolt of the A/C tensioner pulley to loosen the tension of the A/C belt.
  4. Remove the A/C compressor belt.
  5. Loosen the locknut on the face of the power steering/alternator tensioner pulley.
  6. Turn the adjusting bolt of the tensioner pulley to loosen the tension of the belt.
  7. Remove the power steering/alternator belt.
To install:
  1. Install the power steering/alternator belt first and then the A/C compressor drive belt.
  2. Adjust the belts to the proper tension by turning the adjusting bolts and tighten pulley fixing nut/bolt.
  3. Tighten the mounting nut of the power steering/alternator tensioner pulley to 36 ft. lbs. (50 Nm).
6helpful
3answers
How do you remove the alternator on a 2001 continental
2001 Lincoln Continental 4.6L engine
Alternator replacement
1. Disconnect negative battery cable
2. Drain radiator coolant until coolant has drained from overflow bottle
3. Disconnect overflow hose at bottle
4. Remove 2 top power steering reservoir bolts and position reservoir out of the way
5. Disconnect coolant level sensor and bottom hose from coolant overflow bottle
6. Remove retaining nut and bolt
7. Remove coolant overflow bottle
8. Remove drive belt
9. Remove 4 fasteners from top alternator bracket and remove bracket
10. Remove attachment bolts and alternator from vehicle
11. To install reverse proceedure
12. Fill radiator and overflow bottle
13. Bleed air from cooling system
I need a diagram to see were my tension-er is
I don't have the figure for your car, but the below figure shows how to remove the A/C belt.
the other belts should have a simple slot in the bracket for adjusting. If you have more questions, let us know.
3.0L SOHC Diamante
To install:
NOTE The manufacturer does not provide a torque specification for the bolt that secures A/C tensioner pulley.
  1. Connect the negative battery cable.
Changing alternator
2.2L Engines
CHRYSLER ALTERNATOR
  2. Label and disconnect the wiring (for easy installation).
  3. Remove the air conditioning compressor drive belt, if equipped.
  4. Loosen the alternator adjusting bracket bolt and adjusting bolt. Remove the alternator belt.
  5. Remove the bracket and mounting bolts.
  6. Remove the pivot bolt and nut.
  7. Lift the alternator from the vehicle.
When lifting the alternator out of the vehicle on some years with A/C, clearance may be restricted by the condenser cooling fan assembly or the A/C compressor and mounting bracket assembly, if so, removal of one of these items will be necessary.
To install:
  1. Position the alternator against the engine.
  2. Install the pivot bolt and nut.
  3. Install the mounting bracket bolts, and adjusting bolt.
  4. Install drive belts and adjust to specification.
  5. Tighten all the mounting bolts and nuts.
  6. Connect all alternator terminals.
  7. Connect the negative battery cable.
BOSCH ALTERNATOR
  2. Disconnect the wiring and label for easy installation.
  3. Remove the air conditioning compressor drive belt.
  4. Loosen the alternator adjusting bracket locknut and adjusting screw. Remove the alternator belt.
  5. Remove the bracket locknut and mounting bolt.
  7. Remove the alternator from the engine.
To install:
  2. Install pivot bolt and nut.
  3. Set the mounting bracket in place and install the bracket mounting bolt and locknut.
  4. Install the drive belts and adjust to specification.
2.5L Engines
2.5L engines were equipped with either Chrysler or Bosch alternators.
  2. Remove the drive belts.
  3. Remove the adjusting bracket-to-engine mounting bolt.
  4. Remove the adjusting locking bolt and nut, then remove the mounting bracket.
  5. Position the alternator to gain access to the wiring.
  6. Disconnect the wiring and label for easy installation.
  7. Remove the pivot bolt, nut, and washers.
  8. Remove the alternator assembly from the engine.
To install:
  1. Position the alternator assembly against the engine.
  2. Loosely install the pivot bolt, washers, and nut.
  3. Attach all wiring connectors to the alternator.
  4. Position the mounting bracket in place, then install engine mounting bolt.
  5. Loosely install the adjusting locking bolt and nut.
  6. Install the drive belts, and adjust to specification.
  7. Tighten all mounting bolts and nuts.
  8. Connect the negative battery cable.
2.6L Engines
2.6L engines were equipped with Mitsubishi alternators.
  3. Remove the adjusting strap mounting bolt.
  4. Remove the drive belts.
  5. Remove the support mounting bolt and nut.
  6. Remove the alternator assembly.
To install:
  1. Position the alternator assembly against the engine, then install the support bolt.
  2. Install the adjusting strap mounting bolt.
  3. Install the alternator belts and adjust to specification.
  4. Tighten all the support bolts and nuts.
  5. Connect all of the wiring terminals to the alternator.
3.0L Engines
The 3.0L engines were equipped with either the Nippondenso or Bosch alternators.
  2. Install a 1 / 2 in. breaker bar in the tensioner slot. Rotate counterclockwise to release belt tension and remove poly-V belt.
  3. Remove the alternator mounting bolts (2).
  4. Remove the wiring and remove alternator.
To install:
  1. Position the alternator onto the engine, then install the wiring.
  2. Set the alternator against the mounting bracket and install the mounting bolts.
  3. Rotate the tensioner counterclockwise and install poly-V belt.
  4. Connect the negative battery cable.
3.3L and 3.8L Engines
The 3.3L and 3.8L engines were equipped with the Nippondenso alternators.
  2. Remove the alternator drive belt, by relieving the tension on the dynamic tensioner.
  3. Loosen the nut on the support bracket at the exhaust manifold, do not remove it.
  4. Remove the alternator tensioner/power steering bracket bolt.
  5. Remove the tensioner stud nut and remove the tensioner.
  6. Remove the alternator mounting bolts.
  7. Remove the power steering reservoir from the mounting bracket, do not disconnect the hoses, and position it out of the way.
  8. Remove the alternator support bracket bolts. Remove the intake plenum to alternator bracket bolt and remove the alternator support bracket from the engine.
  9. Remove the alternator from the engine and disconnect the electrical leads.
To install:
  1. Install the alternator in position on the engine and connect the electrical leads.
  2. Install the alternator support bracket, tighten the retaining bolts to 40 ft. lbs. (54 Nm).
  3. Install the power steering reservoir on the mounting bracket.
  4. Install the alternator mounting bolts, tighten the bolts to 40 ft. lbs. (54 Nm).
  5. Install the tensioner and tensioner mounting stud. Install the retaining nut on the exhaust manifold.
  6. Install the alternator belt, insert a 1 / 2 in. extension into the square hole in the tensioner and turn the tensioner. Tighten the tensioner bolt.
Hope this help (remember comment and rated this).
2helpful
4answers
I cannot get the alternater out of my 1997 Dodge Grand Caravan. It is a 6 cylindar 3.3 engine. The Chilton manual is no help at all. I have managed to remove all the bolts holding it on, but I cannot even...
3.3L & 3.8L Engines
  2. Remove the windshield wiper/motor module assembly.
  3. Remove the accessory drive belt.
  4. Remove the bolt securing the top of the alternator mounting bracket to the engine air intake plenum.
  5. Remove the bolts securing the outside of the alternator mounting bracket to the alternator mounting plate.
  6. Remove the bolt securing the top of the alternator to the mounting bracket.
  7. Remove the alternator mounting bracket from the vehicle.
  8. Rotate the alternator toward the dash panel.
  9. Unplug the push-in field wire connector from behind the alternator.
  10. Remove the B+ nut and wire from behind the alternator.
Alternator removal-3.3L and 3.8L engines
  1. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
  2. Remove the alternator from the vehicle.
To install:
  1. Install the alternator into position on the vehicle's engine.
  2. Install the bolt securing the bottom of the alternator to the lower pivot bracket.
  3. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  4. Plug in the push-in field wire connector onto the back of the alternator.
  5. Rotate the alternator forward away from the dash panel.
  6. Install the alternator mounting bracket in position on the vehicle.
  7. Install the bolt to secure the top of the alternator to the mounting bracket.
  8. Install the bolts to secure the outside of the alternator mounting bracket to the alternator mounting plate.
  9. Install the bolt to secure the top of the alternator mounting bracket to the engine air intake plenum.
  10. Tighten all of the alternator mounting bolts to 40 ft. lbs. (54 Nm).
  11. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
  12. Install the windshield wiper/motor module assembly.
  13. Reconnect the negative battery cable.
  14. Verify the charging rate of the alternator.
LET ME KNOW IF THIS HELPED.
Replacing alternating belt
A good repair manuel to get which has picture step by step, Hanyes auto repair manuel at any aut part store for 20 bucks is a great investment.
.0l Engines The 3.0L engines were equipped with either the Nippondenso or Bosch alternators.
2. Install a 1/2 in, breaker bar in the tensioner slot. Rotate counter-clock- wise to release belt tension and remove poly-V belt.
To Install:
5. Position the alternator onto the engine, then install the wiring.
6. Set the alternator against the mounting bracket and install the mounting bolts.
7. Rotate the tensioner counterclockwise and install poly-V belt.
8. Connect the negative battery cable. 3.3L and 3.8L Engines
The 3.3L and 3.8L engines were equipped with the Nippondenso alternators. 1. Disconnect the negative battery cable.
8. Remove the alternator support bracket bolts, Remove the intake plenum to alternator bracket bolt and remove the alternator support bracket from the engine.
To Install:
10. Install the alternator in position on the engine and connect the electrical leads.
11. Install the alternator support bracket, tighten the retaining bolts to 40 ft. lbs. (54 Nm). Install the power steering reservoir on the mounting bracket.
13. Install the alternator mounting bolts, tighten the bolts to 40 ft. lbs. (54 Nm).
14. Install the tensioner and tensioner mounting stud. Install the retaining nut on the exhaust manifold.
15. Install the alternator belt, insert a 1/2 in. extension into the square hole in the tensioner and turn the tensioner. Tighten the tensioner bolt.
16. Connect the negative battery cable.
How do you replace the alternator on a 2000ford contour
Removal & Installation
2.0L Engine
  2. Remove air intake resonators.
  3. Remove the air cleaner-to-throttle body tube and the mass airflow sensor.
  4. Unplug the connectors and remove the cables from the alternator.
  5. Raise and support the vehicle.
  6. Release the drive belt tensioner and remove the drive belt from around the alternator.
    NOTE It is not necessary to remove the drive belt from the engine.
  7. Remove the alternator mounting bracket bolts and remove the mounting bracket.
  8. Lower the vehicle.
  9. Remove the power steering pressure hose bracket retaining nut and bolt and remove the bracket with the hose from the engine lifting eye.
  10. Remove the alternator mounting bolts and remove the alternator from the vehicle.
  11. To install:
    1. Place the alternator into position and install the mounting bolts finger tight.
    2. Install the power steering hose bracket and tighten the retaining nut and bolt to 70-106 inch lbs. (8-12 Nm).
    3. Raise and support the vehicle.
    4. Install the alternator mounting bracket and retaining bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
    5. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
    6. Lower the vehicle.
    7. Tighten the alternator mounting bolts to 15-22 ft. lbs. (20-30 Nm).
    8. Install the alternator connectors and the cables. Tighten the terminal nut to 80-97 inch lbs. (9-11 Nm).
    9. Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
    10. Connect the negative battery cable. To install:
1helpful
Zx5 2004 ford focus alternator broken
disconnect the battery & make sur you have your radio code, then remove the belt.
it's pretty simple there's a nut in the middle of the tensioner wheel, get the right size socket & using a ratchet, move the tensioner by locking the rathet & do or undo the nut, as it's a fixed nut used to swivel the tensioner.
Then undo the wiring on the back of the alternator, usually a click in multiplug and a + power cable boted on with a 10mm nut.
then remove anything in the way of the alternator securing bolts, & remove the bolt's, alternator should be free !
But I don't suggest you do it yourself unless you have a reasonable grasp of mechanics, as I have had to do this job properly after some people have tried themselves & they've made it worse, plus once the belt's off you have no power sterring so you can't drive it to the garage if you can't get the belt back on !
2answers
I need to replace my alternator
You need to first take off youre serptine belt. Inspect that and generally its a good idea to replace. Next there is a electrical connection on the alternator. DISCONNECT the battery FIRST!!!!!!!!!!!!!!!!!!!!!!!!! then disconnect the connection on the alternator, there are a couple of bolts that attach the alternator to the engine. and then simply bolt on the new one, re-attach the electrical connection and then re-install the (new) belt.
1helpful
2answers
Replace alternator
This is for both size engines since you didn't list the motor size......
REMOVAL & INSTALLATION 2.0L Engine
  6. Release the drive belt tensioner and remove the drive belt from around the alternator. NOTE: It is not necessary to remove the drive belt from the engine.
  10. Remove the alternator mounting bolts and remove the alternator from the vehicle. To install:
  11. Place the alternator into position and install the mounting bolts finger tight.
  12. Install the power steering hose bracket and tighten the retaining nut and bolt to 70–106 inch lbs. (8–12 Nm).
  13. Raise and support the vehicle.
  14. Install the alternator mounting bracket and retaining bolts and tighten to 15–22 ft. lbs. (20–30 Nm).
  15. Release the drive belt tensioner and install the drive belt pulley over the alternator pulley.
  16. Lower the vehicle.
  17. Tighten the alternator mounting bolts to 15–22 ft. lbs. (20–30 Nm).
  18. Install the alternator connectors and the cables. Tighten the terminal nut to 80–97 inch lbs. (9–11 Nm).
  19. Install the air cleaner-to-throttle body tube, mass airflow sensor, and the air intake resonators.
  20. Connect the negative battery cable.
Top Subaru Heating & Cooling Experts
Paul Carew
john h
Are you a Subaru Heating and Cooling Expert? Answer questions, earn points and help others
