I have cleared out the filter, remove the pump it it looks clean. Nothing around propeller. I remove drum drain hose, it's clear.I think my pump might be dead, I hear a humming noise when it get ready to drain but it doesn't.
Hi if you remove the pump again get a plug and wires example from a table lamp and attach 2 wires to the pump dont worry about polarity it will run both ways plug into the wall see if the pump runs out of the machine ( does this model have 2 pumps one could be the recirculation pump)
Thank you, it sure help to determin if pump was working.
now that I verify the pump is working what other issues will prevent the washer from draining, with the code of OE?
the washer only has one pump.
Thank you, you were great help and save me money in not having to buy other pump. Since current one was working. Issue that I found was clogged drain hose. Again thank you
