I suspect that you do not have a problem. . The standard operating temperature of a freezer is around -20 degrees CENTIGRADE (-2 Farenheit)
Your freezer has an option to display degrees C and degrees F, I suspect it is showing farenheit
I have taken a look at a copy of the manual, which can be found at:
http://www.manualowl.com/m/Samsung/RF217ABBP/Manual/142915But for the life of me, I can't see how to change the display from C to F and back anywhere in the guide. If I am right, swapping the display back to Farenheit will solve the display issue.
If you are unable to change the display, you can try calling Samsung in arlington NJ on 1-800-726-7864.
Hope this helps. Please add a comment to this thread to let me know if the problem is solved or if you need more help
