Mach Speed Trio Stealth Pro 7C 4GB 7" Capacitive Touch Android Tablet - SP7C Logo
Debra Kasunic Posted on Dec 26, 2014
How do I add IP address to Stealth Trio Android Tablet?
1 Related Answer
robertmoore1
  • 179 Answers
  • Posted on May 10, 2015
SOURCE: Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
Have a Trio Stealth -10 wont connect to the WiFi
Is wifi turned on on the tablet? If not, go to Settings>Wifi and turn it on. The device should then automatically scan for networks.
If you are able to connect to your network but then cannot actually get to the Internet you may just need to restart your router. You might get something like "Obtaining IP address" for a long time and then get "Limited" connection. Correcting this may be just a matter of unplugging it for about a minute then plug it back in. Wait 4-5 minutes for the router to boot up completely then try connecting again. Some routers are sensitive to new devices. When I had AT&T Uverse router I would have to restart it every time I tried to add a new wifi device.
Hope this helps.
2answers
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
2answers
Where can I buy a charger for my trio stealth g2 tablet?
I was able to use my cell phone charger when my Trio Stealth Tablet charger stopped working. I would suggest first trying to use a basic cell phone charger before going out and spending lots of money on a charger "specifically" for a tablet.
Can kindle be install on my mach trtio stealth pro
Go to the android app's store and download the "Kindle" app or any of the Ebook reader app's.But be aware if you are a "Kindle" user you will have to use their app to read your Kindle books.
If the app doesn't work email Kindle for a patch for your tablet.
HTH
I can not connect to internet with my stealthg2 eventhough wifi strength strong
check to see if it's doing MAC filtering(turned on) if so you need to add your mac address for the device
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
2answers
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Trio Stealth pro 7 inch tablet will not boot up
http://www.slatedroid.com/topic/41611-rooting-procedure-the-trio-stealth-pro-97/
javascript:void(null);
Top Mach Speed Trio Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Mach Speed Trio Water Sport Expert? Answer questions, earn points and help others
