Nothing
It sounds like you understand that the exhaust fan is SUPPOSED TO come on when the microwave oven gets hot when exposed to the heat of the range below it, since you mentioned that no burners are turned on. So in that case, I'm pretty sure that you have a bad fan thermostat. It's usually located behind the control panel on the bottom (inside bottom) of the microwave floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
