Mine is slightly different, but I suspect the date adjustment is the same. Pull the middle knob on the right out VERY gently. You have to stop at the first click. Then turn it to set the date.
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Fossil do not have a list of instructions under model numbers but issue a list of generic instructions which you have to wade through to find the one that suits your watch.
If it's the same watch I have, the four dials from right to left are day of week, hours left in the day, date 1-31, and possibly a chronograph (mine makes 2 revolutions/minute). On the case, there are three large knobs on the right and two small flush screw-like objects on left. The large knobs (top to bottom) are month selection, time set, and day of week select. Month and day can be selected by pushing the knob to the desired date. On the left, you will need a fine pen or stylus to press the center. Top to bottom, these two buttons control year and date selection.
To set th watch you pull the round knob out on the right side. When you pull it out you turn the knob in a clockwise direction to set the date and time.
the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
pull the middle dial out to put it in alarm mode.
To set alarm:
-pull the center knob out.
-with it out you can now use the bottom (right) knob to set the alarm.
-pull the bottom right knob out one notch
-turn the knob clockwise or counter clockwise to set the alarm time
-push the knob back in (all the way)
the alarm is now set
if the center (right) knob is pulled out the alarm is ON
if the center (right) knob is pushed in the alarm is OFF
I have owned this watch for about 10 years now and love it.
the past few years the chronograph buttons (on the left side of the
watch) were not working well rendering the chronograph and count down
timer functions unusable.
repairing a chronographs is expensive and watch makers usually charge
several hundred dollars which is not a feasible fee for a watch of this
value so i decided to open it up my self and clean it up and that did
the trick.. its working like new!
There should be 3 knobs on the right side of your watch. Unscrew the middle knob with the crown on it until it pops out. After it springs out, it will be in winding mode. You want to gently pull it out past this point, it will click into place and you will be able to set the time by turning the knob. After time is set just push the middle knob back in and turn clockwise unitl it is tight.
1. Pull out the time set mode button. 2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60. 3. Press the time set button back into normal position.
