Rescanning and turning tv on and off. we don't have a wifi dongle to connect to!
Hi!i have just the same problem,i made a factory reset and it looks like it helped no more flashing message
er 0 0 Best way to cure this problem is to remove offending wifi module open up tv and module is situated at the bottom right hand side remove connection and remove module Then put back on tv and away you go Hard wire into modem is best or buy new module on ebay SORTED.
Read more: My luxor tv keeps flashing wifi dongle removed/detected why is this how do you stop it? - Wifi dongle removed/detected keeps flashing on my screen :: Ask Me Fast athttp://www.askmefast.com/My_luxor_tv_kee...
SOURCE: Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
SOURCE: Samsung smart tv is detecting my wireless router
Watch out for passwords with capital characters! Also don't confuse the character "O" with the number "0". ;)
I hope this helps!
SOURCE: how to connect a WIFI
I understood your problem...You can also do it via ps3 if it has the wireless card..
or
60pz570 is WiFi only, so you need WiFi to connect and register the
device. You can go to any location that has free WiFi, and do this
(such as a Barnes and noble, Starbucks or even McDonald's). You would
also need WiFi in order to download books to the device, however you do
not need a connection in order to read them once they are on there.
There is no nookcolor with 3g capabilities. The original nook (the
black and white eink screen) does have 3g, so you are able to download
books from anywhere.
SOURCE: how do we get our panasonic smart viera to connect to internet via the dongle sold with the tv
You may have to study the operation manuals of both.
Have you tried unplugging it and plugging it in again?
