Thank you for your post, Corey!
From the information you have posted you need to replace the internal light bulb in your Electrolux dishwasher. In order to assist you properly I would need to have your model number. You can locate your serial tag (which lists your model number) on the inside left hand wall of your dishwasher. Once I have that additional information I would be able to provide you with proper instructions on how to replace the bulb. I look forward to assisting you further. -Matt
Hi
If the water inlet
valve is fine and it fills with water then the issue seems to be with the float
switch assembly that is bad and should be replaced. Float assembly is found
inside the dishwasher's tub, on the bottom. The water that fills the dishwasher
lifts the float, and when it reaches a certain level, it acts as a trigger for
the float switch. The float triggers the float switch to shut off, thereby
shutting off the flow of water into the dishwasher. A defective switch may
interfere with dishwasher's filling and/or draining ability. Use voltmeter to
test the switch. Set the device to the ohms setting x 1. Take each probe and
touch them to one switch terminal each. This should produce a reading of either
zero or infinity. Continue to touch the probes to the terminals, and press down
on the switch's button. The reading should change to the opposite extreme. If
the switch fails either of these tests, you should replace it. Hope this helps...please post back for
further assistance.
Daniel
