I went to the website and brought it up, and it says to proceed to movietube 4.3.3 download page, and when i do that it says downloadlocations for movietube 4.3 v4.3.3. and when i look for the install button, i don't see any. so how do i install it to my tablet.
All you need is to go on Movietube 4 3 App Download For Android Apk and download the latest version from that site, then when downloaded simply open any file manager and locate the file (mostly it goes in download folder) when located tap on it and you will be able to install it without any problem. if this solves your problem dont forget to say thanks to me.
On a tablet all your down loads are in the " my files " which must be accessed in the pull down menu , if you opened it in a browser.
However movietube is in the play store as an app . if you got it from the app store . and it installed but is not showing then you have a full screen an need to tap the all apps icon lower right corner . it is the square with rows of dots. then search till you find it. if not then get it from the app store / play store i checked and it is there.
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
SOURCE: Why isn't the X showing up when I try to delete an app on my tablet? Can I fix it?
Alot of preloaded apps can't be deleted unless you put an aftermarket system on your tablet
SOURCE: I downloaded an app---now how do I install it.
If you had downloaded from Google Play the app would be installed automatically. If you DL from a website, the file may need to be "sideloaded". Try googling "sideload Android app" to get simple instructions or a small additional app that can unpack and install packed apps on your device.
