Tablets & eReaders Logo
A
Anthony Rodriquez Posted on Dec 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Tried redoing the settings and ok
Mike
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Tablets & eR... Master 884 Answers
  • Posted on Dec 26, 2014
 Mike
Level 3:
Renaissance:
Answers
884
Questions
Helped
195267
Points
4435
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
2answers
Amazon Alexa Dot unit won't connect to the Internet while other WiFi devices connect fine. Doing the Alexa Dot Setup doesn't help. WiFi Router Modem was changed recently.
  • Plug your Echo Dot into a power outlet.
  • Open the Alexa app.
Saving Your Wi-Fi Passwords to Amazon FAQs.
  • Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
  • Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app. You're now ready to use Alexa.
  • 0helpful
    Our new kindle paper white will not connect to our wifi
    The Kindle Paperwhite automatically scans for Wi-Fi networks that are in range of your device. If one networks are found, the device will connect automatically. If a password is required, a screen appears asking you to input that information. Generally, the process is quick and easy.
    Occasionally, however, you may need to connect to the Wi-Fi network manually. Follow these steps:
    1. Tap Menu?Settings.
    2. If the network to which you want to connect appears in the list, tap that network.You're finished!
    3. If the network to which you want to connect doesn't appear in the list:
      1. Tap Other.A dialog box named Enter Wi-Fi Network appears, along with the on-screen keyboard.
      2. Using the onscreen keyboard, enter the network name and, if applicable, the password.
      3. Tap the Advanced button.
      4. Work through the series of screens, entering information related to the network, including connection type, IP address, and security type.
        Advance through the screens by using the up and down arrows.
        If necessary, contact the person who set up the network for assistance with filling in this information.
      5. When all the necessary information has been entered, tap the Connect button to join the network.
    If your Kindle Paperwhite is connected to your home network but can't connect to Amazon, you may need to reestablish the connection. Tap Menu?Settings?Wi-Fi Networks, and then tap the network that has a check mark to its left. When the Forget Network? dialog box appears, tap Forget. You'll have to reselect the network and enter the password (if one is required).
    If you're having trouble connecting to your home network, unplug the Wi-Fi router, wait at least 60 seconds, and then plug it in and wait for the network to restart.
    If this does not work....follow this link and do a factory reset.
    http://www.wikihow.com/Reset-a-Kindle
    Good luck.
    Semper Fi,
    DrZ
    Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
    It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
    My polaroid tablet model a7 will not authenticate and allow me to go on internet using wi-fi
    Try it with a different router. Use a friends. Your router may have to be adjusted.
    Go on the manufacturers web site and see if your problem is listed.
    9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
    You can try this and see if it works for you:
    Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
    You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
    Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
    Turn on Wi-Fi and connect to a network
    1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
    2. Under "Wireless & networks," touch Wi-Fi.
    3. Touch the Wi-Fi switch to turn it to the On position.
    4. You'll see a list of saved and available networks.
      • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
      • Your device will remember networks it connects to and automatically connect to them when in range.
      • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
    5. Touch a network name from the list of available networks to connect to it.
      • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
    6. Once connected, your device will say "Connected" under the network name.
    Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
    1helpful
    Cant get wi fi signal.
    Solution 1.Check wireless connection.
    The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
    2.Check your Keep Wi-Fi on during sleep Settings.
    Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
    Tweak this policy to keep your Wi-Fi connection awake.
    [Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
    Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
    3.Check signal strength of wireless connection.
    The performance of a wireless network connection depends in part on signal strength.
    You have to connect the Wireless network where the signal strength is strong.
    Check Wireless network signal strength icons in notification bar.
    4.Try to turn off/on Wi-Fi on the device.
    First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
    And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
    5.Try to forget network on the device.
    Forgetting wireless networks allow your tablet/phone to reset some settings.
    [Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
    >>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
    6.Try to reboot your device.
    7.Make sure your firmware is up-to-date.
    >>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
    8.Try to reset your device.
    Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
    Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
    [Settings]>>[Backup&reset]>>[Factory data reset]
    9.Try to other wireless connections.
    If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
    My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
    I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
    How to connect my tablet to wi-fi
    Authentication often means "password protection" for the specific wifi connection. Usually your software will present a "dialogue" box telling you a password is necessary and give you an opportunity to enter one.
    Top Tablets & eReaders Experts
    k24674
    ADMIN Andrew
    ADMIN Andrew
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
