Question about Nostalgia Electrics Mini Popcorn Popper Machine, Tabletop Vintage Hot Air Pop Corn Maker, Ofp-501
How to put together pop corn proper ft454cr
No description manual
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
Apr 27, 2016 | Kitchen Appliances - Others
I lost the instructios for the amount of kernals to put in and if put oil in the well
If you have no idea what brand or model number you have and the kettle is heating properly you can figure it out pretty close just by timing the popping cycle. The ratio is 3 parts corn 1 part oil. so a 12 oz kettle would be 12oz of corn (1-1/2 cups ) to 4 oz of oil. A good popping cycle takes about 3 1/2 min from the time you add the corn and oil to dump time. you can make ajustments for the results you get.
Dec 26, 2015 | Kitchen Appliances - Others
How do you make popcorn in the poppery ll hot air popper? i do not have owners manual
Hi pdfive...
Put one cup of unpopped corn into the machine, turn on and it will auto eject the popped corn into a waiting pan.
Please take time to rate me
Aug 28, 2011 | Vacuums
I have a Star model 89, manufactured in about 1986. Its a 14 oz kettle, and everything works, however the kettle will not pop the corn. The kettle is hot to the touch from the outside, but will not pop...
Make sure your agitator arms are properly functioning. If the corn is not being properly stirred, it will not pop. Also, make sure you are using the correct type of popcorn oil.
Nov 04, 2010 | Star 39 JetStar Popcorn Maker
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
How much oil or corn do you use in the Back to Basics Pop Corn Popper for the stove
unless you have the instruction manual, only trial-and-error will tell you. Start with 2 tablespoons of oil and 1/2 cup of corn kernals. If there is oil left after the corn is popped, decrease the amount of oil by a teaspoon. If the popped corn is burned, increase the oil by a teaspoon. As for the corn, if the pot is full when the popping is done, 1/2 cup is the right amount. If the popped corn over flows, 1/2 cup is too much. Vary the oil and corn until you get it right. Good luck! I love popcorn, so I wish you the best.
Feb 02, 2010 | Back to Basics 6112304 Popcorn Maker
NEED AN INSTRUCTION MANUAL FOR ''OLD FASHIONED MOVIE TIME POPCORN
The usual way to use a pop corn popper is to:
1st - add oil
2nd - add popcorn
3rd - add any seasoning (if using the pre-packaged "theater" popcorn mix).
DO NOT add butter into the popper, as it will burn quickly and make for some foul tasting pop corn.
You can always add butter and salt to taste AFTER the pop corn is done popping.
Hope you find this Very Helpful. Best regards!
Aug 18, 2009 | Kitchen Appliances - Others
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
Microwave will not function properly.
The cavity thermal fuse may have failed. It is located on the top of the cavity.
Jun 13, 2008 | Microwave Ovens
No user manual
keep the lid on, you can put butter up top to melt
Dec 02, 2007 | West Bend 82306 Stir Crazy® Popcorn...
Nostalgia Electrics Mini Popcorn Popper Machine, Tabletop Vintage Hot Air Pop Corn Maker, Ofp-501 Logo
55 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Anthony Ward
Anthony Ward
Sheldon Dedek
Gil Shultz
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
