1995 Jeep Grand Cherokee Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lighter and dash lights on our jeep grand
The lighter and dash lights on our jeep grand cherokee have stoped working and we are trying to find a diagram of the fuse box to figure out which one it is the year is a 1995
nathan
Level 3:
  • Master 634 Answers
  • Posted on Jul 06, 2009
nathan
Master
Level 3:
Answers
634
Questions
0
Helped
290280
Points
1974
U can use wire prob and tap back of fuses on metal contacts and whe it doesn't like on both side it is blown pull and replace
1helpful
Cigarette lighter socket not working in my 2004 Cherokee. Guessing it's a fuse blown. Where is the fuse box located and which fuse do I need to check? I don't have a service manual to consult. Thanks.
I looked at info, 04 jeep grand cherokee laredo. The junction block should be under left side of dash. I don't know, my database only showed the grand cherokee? Hope it's the same?
Heated seats on jeep grand cherokee dont work, no dash light
you need new heaters. I've replaced dozens on that model.
All my power outlets and cigarrette lighters don't work in my 2005 jeep grand Cherokee. I've checked and swapped out fuses and it stoo don't work. What else can I check?
sometimes these are on a circuit breaker check with a test light for power in the center of your socket then be sure to check the ground if no ground or power always go back to source this circuit may even have a relay
Jeep electric windws and locks
I work for a dodge chrysler jeep dealership,we replace alot of regulators in grand cherokee's,have replaced a few window switches,your dash light problem is more than likely in the head light switch,try working the brightness control and see if that helps
I have a 2000 grand cherokee v8 and ive got battery problems
something is draning the battery.
it has to be the dash lights the dome lights or something being left in the cig lighters
or the lights arnt turning off after you close the door.
or an after market stereo was installed wrong and or the aftermarket amp.
keep me posted
jm
Every time i use my lighter it blows fuse for radio lighter and dash lights where does fuse go
Usually the fuses are under the steering wheel to the left and up against the firewall, like in front of where your left knee would be. There is a plastic door that you need to open to get to them. Its the fuse marked "radio". Your lighter might have a short. Or you could try a 25 or 30 amp fuse as to replace the blown one. If your radio is off and lights to the dash are off and the fuse still blows when you use the lighter you need a new lighter
1helpful
All warning lights on dash come on and all electrics stop working
The common problem with the dashes on the Jeep is contacts. Remove the cluster and try cleaning the electrical contacts with a Q-tip and alcohol replace cluster and try again.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
