Question about Janome Hello Kitty 18750 Computerized Sewing Machine - -
How do i clean my 18750 sewing machine?
I have read my manual and i need more info to know how to take good care of my machine.
    Scholar:
    New Friend:
  • 109 Answers
Caring for and cleaning a sewing machine is much the same no matter what model/make, I can't actually see a manual for yours but in general terms this is what I do.
Keep it covered and out of direct sunlight when not in use, sunlight is tough on plastic shell cased machines. Also unplug the power lead when not using, just in case of electrical fusion.
Each time you use your machine do the following (I do it when I start a new project, then clean before putting away in the cupboard if I'm not going to be back to it for a while):
wipe external surfaces to remove any thread dye particles, lint or dust. Unplug, then lift presser foot and unscrew the metal cover plate and remove to expose the bobbin case. Remove the bobbin and then lift out the bobbin holder. (With my Janome, this is held in by a magnet and there are two markings that line up to realign the case). Brush out all lint that you can get to or use tweezers to remove, you don't want to blow it further into the machine so never use canned or compressed air. Clean the bobbin holder too. With mine, there is a little wick for lubrication in the middle of the race, add a drop of good quality clear sewing machine oil, then replace the bobbin holder and cover plate.
how do i clean my 18750 sewing machine? - 25337008-k4hvezj240pt3jcsmcbnor2m-1-0.jpg
Clean the tension discs, to do this raise the presser foot, then "floss" between the tension discs (that dial on the top front) with a piece of clean waste fabric like calico or cotton, to remove any lint or thread dye particals which can build up. I also use a felt circle under my thread spool as it helps with the thread running smoothly off the spool, I'll lift this off and clean underneath and around the back where the spool sits as the dust/dirt builts up here too.
I also throw out the needle after each project is finished, a needle is good for 6-8 sewing hours at most, depending on the material sewn. If you hear squeaking or popping when stitching slowly, your needle is blunt. Also watch for burrs on the needle tip, the needle does all the work so it pays to be fussy and change regularly. And use the correct needle for the project, sharps for wovens, ball points for knits and jerseys, and the right size, ie a 60 or 70 for very fine fabrics like organza and chiffon, 80 for poplins, 90 Jeans for denim, and 110 for very heavy materials like coatings and curtain/upholstery.
And keep magnets away from electronic machines, don't have a magnetic pin cushion on the free arm, not good for them.
Posted on Mar 02, 2015
SOURCE:
Do I oil a janome magnolia 7330?
If it is a computerized machine, oil only as instructed in the owner's manual.
If it is mechanical, a drop of good quality sewing machine oil ever place where metal rubs against metal.
Jun 30, 2018 | Janome Sewing Machines
I'm trying to load my bobbin on my singer 628 and the bobbin doesn't wind. Any ideas?
Anon, Found links to help with bobbin does not wind, make sure to read the articles in the forums, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20070630202938AAGRwx2
Singer 628 Touch and Sew sewing machine manual smm043 Machines name begins...
Thread Singer 628 Touch and Sew Questions
Apr 05, 2016 | Singer Sewing Machines
How to oil my machine
-Here are the basic.
Flip it over and turn it by hands. Lube all moving part that connect together. If too much oil, wipe it out.
This is sample.
Good Luck
mai
Jul 21, 2015 | Sewing Machines
Where can i get pictures of my 18750 hello kitty instructions for cleaning my sewing machine
check with sewvacdoctor.com or A1sewingmachines.com and see if they can help you with a manual.
Dec 25, 2014 | Janome Hello Kitty 18750 Computerized...
White XL1760 cant find the setting for the straight stitch.....a, b, c????
You can download a manual for your White machine from the Singer website, link is
http://www.singerco.com/uploads/download/1111_white-1760-xl-x.pdf
Here are the relevant pages from the manual:
Straight stitch settings as follows:
stitch length on 2.5 (selector marked with blue arrow)
stitch width on zero (no swinging of the needle) selector marked with red arrow
stitch selector on A - selector marked with green arrow
Generally all sewing machines will have a similar three controls, because all stitches are a combination of moving the fabric forward a certain amount between the needle going through the fabric - the stitch length; and moving the needle from side to side - the stitch width.
And then a stitch selector for different stitch forms such as a blind hem or shell stitch where the needle is going through a series of different moves in sequence to form a special stitch. You still have the width and length controls to vary this formation.
For general sewing machine information www.sewing.about.com is excellent, there is lots of pages on general tips, cleaning, threading up and sewing machine know how. Try this page to start http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machines.--9k/
If you are a beginner, then I'd recommend printing out the instruction manual for your machine and putting into a binder, placing beside the machine, and carefully read from the beginning going through all the instructions to wind a bobbin, thread up, three or four times until you can do it without reading the manual, then practice stitching out each of the stitches your machine does. Buy a cheap exercise book and on each page, write the name of the stitch, staple the stitch sample in and either write down the settings used or glue in a photo taken of the machine controls you used. This way you can quickly flick through and refer to your settings next time. ADjusting the top tension dial will also adjust the stitch formation so read the manual and set the tension dial to the setting it suggests but sometimes you'll need to adjust it slightly to get the stitch looking even (balanced between top and bottom thread), especially for zigzags.
Practice a bit and you'll soon feel much more confident using the machine. Also, refer to the cleaning and oiling instructions and do it regularly, along with changing the needle for each new sewing project, about 4-6 hours sewing time. The needle is the most important part of a sewing machine, always use the right sized needle for the fabric. Refer here for info http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
I hope this helps you with your White sewing machine, there are lots of great sewing machine books on the market too or in your public library to refer to. Also taking beginner sewing classes will really help you learn how best to use your machine. I've been sewing for over 38 years but still enjoy going to a class and learning a new technique from another enthusiast - life long learner!!
Jul 18, 2011 | Sewing Machines
I've borrowed a Silver 302 from my neighbour, and after a few hours use, it's started squeaking. Loudly. I don't know if this model needs oiling or not, and if not, what it may need doing to it - just...
I'm not familar with this machine but will make some general suggestions. I did google it and found a 502 http://www.silverviscount.co.uk/shop/product_info.php?cPath=21&products_id=40 it looks like a economy front loading bobbin machine.
If you manually turn the fly wheel to form the stitiches and listen carefully can you hear a popping as the needle enters the fabric? If yes, its a needle problem. All machines need a new needle for each sewing project, 4-6 hours sewing time, before they go blunt. Cchange the needle for a new one in the right size for what you are sewing (ballpoint for knits, sharp for wovens). Refer to www.sewing.about.com for good general info on machine maintenance, needle sizes and types and threading diagrams, its a wealth of information.
If its not a needle issue then I would suggest that you open up the front flap, remove the bobbin holder, needle and pressure foot and clean out the race area with a small brush, then again manually turn the fly wheel and add a little drop of good quality machine oil to anywhere where you can see metal moving against metal and see if this quietens down the squeaking. Don't use 3-in-1 oil.
You could also ask the neighbour for the manual and check out if it does have oiling points to try and eliminate this as a cause.
Hope this helps a little.
Mar 08, 2011 | Sewing Machines
How to adjust tension the underside stich is loose and tangled, the top stich is fine
Usually it is your top threading is not right, double check that. Read you manual carefully, even if you think you know how to thread it, do it over again. Good luck
Jul 24, 2010 | White Sewing 935 Mechanical Sewing Machine
Need help with correct cotton feed for Husqvarna Viking
What a great machine! I found an excellent review of this machine and your manual for sale at http://www.sewingonline.co.uk/machines/viking19e/.
This is in England, but I've ordered manuals, books, etc from England before with no problem.
You really need a copy of the manual. for most of my machines (but I don't have a VIking) the bobbin unwinds from left to right--but this is no quarantee yours does the same. Each machine is a little different.
Sometimes a good cleaning (being sure to get out all the lint from the bobbin assembly area), a new needle, and a careful rethreading will solve this sort of problem-- but you still need the manual.,
Good luck and again, congratulations on buying a great machine! Let me know if this solves your problem.
Robbie
Jan 31, 2010 | Husqvarna Sewing Machines
Taking care of my machine
Almost all new, computerized machines do not require oiling. Be sure to clean the lint out of the bobbin area every time you change the bobbing. A pipe cleaner will get into small places. Best bet is to check your manual or talk to your sewing machine repairman. Another hint is to always use good thread--that can save a lot of headaches.
Nov 09, 2008 | Janome Memory Craft 9000 Computerized...
Janome Hello Kitty 18750 Computerized Sewing Machine - - Logo
372 people viewed this question
Top Janome Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Carolyn Rogers
thinksewfast
Are you a Janome Craft and Hobby Expert? Answer questions, earn points and help others
