I have tried to reset the doorajar with the reset button and turned the freezer completely off. Raised and lowered the temperature.
Check that the door gasket is not perished or damaged causing the door not to close properly. Also check nothing is hitting or obstructing the door from pushing the door open switch closed. Some fridges have a lever or button sticking up out of the door which pushes the switch off. Check if you have one and see if its broken or missing the switch. Perhaps the door has dropped and not touching the switch? The moisture in the fridge indicates that air is getting into the compartment during cooling cycle. This is common if the door isn't closing properly or the gasket has failed.
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first. 1. Is there a thick frost buildup on the back panel at the bottom half of the freezer? 2. Do you hear the fan running inside the freezer? Let me know what you find.
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
SOURCE: freezer alarm
nana,
Your defrost elements are not working or the inlet to the evaporator tray is clogged, if you haven't gotten iny icy water build-up in the bottom of the fridge you will soon. This may require a service call.
randy320sgi
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
SOURCE: freezer not working on ariston fridge freezer 2
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
