Honda 2002 Odyssey Radio Logo
Richard l Williams Posted on Dec 25, 2014
Code for radio Honda odyssey 2002 - Honda 2002 Odyssey Radio
Demarcus Jones
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 04, 2015
Demarcus Jones
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
711
Points
My email is [email protected] . what size is your motor
3answers
Need radio code for 2002 odyssey ser #1110 8601
Accessing Your Honda Radio Code Online Visit https://radio-navicode.honda.com/. You will need your Vehicle Identification Number (VIN), phone number and zip code matching the information on file with Honda, and the device serial number. You can retrieve your code through the website Sunday-Friday 4:00AM - 9:00PM PST and from 4:00AM - 6:30PM on Saturdays
To Access Your Honda Radio Code via Phone Call Honda America Client Services at 1-800-999-1009. You will be required to provided your VIN number, radio serial number, as well as proof of ownership.
To Access Your Honda Radio Code from a Dealership Drive to your local Honda or Acura dealer and provide your radio serial number and proof of ownership.
Your radio code will not change, so once you've retrieved it, write the code down for any future use.
IF YOU NEED RADIO CODE PLEASE READ THIS THREAD Honda Tech
2answers
I have a 2002 Honda oddesey need the code for the radio
Honda assigns a specific code to each radio. If you have the original Honda manual package, there should be a small white business sized card from Honda with the radio code. If you can not find the card, the local Honda Dealership can look it up for you.
I need a code for 2002 Honda Odyssey
You can get help at honda.com concerning the radio code.
Code radio
What is the radio code for Honda Odyssey 2002
I have a 2002 honda odyssey van and i need the radio code
I actually had the same problem today and found the code in the weirdest place. I keep all of my maintenance receipts from the dealership and found the code on an oil change receipt. Very clearly said, "Radio Code".
4helpful
2answers
1999 Honda Odyssey loses power and shuts of while driving.
Your ignition switch is likely overheated or worn out. I repaired mine by just changing out the electrical connector portion of the switch.
Resetting radio code
You need to be very careful Each failed attempt causes a long delay before you can enter it again. Follow the instructions exactly. You may need to use the car for a day or more before attempting it again if you failed too many times. The radio should say CODE not ERROR. Error means no code can be entered now. You must wait until the radio displays CODE.
3helpful
Radio code for Honda Odyssey 2002
Hello! take your details i.e. Log book/title proof of ownership and identification to your local Honda dealership they will be only glad to take a few bucks from you for the supply of the code.
Please press the Blue Button in appraisal of my FREE! effort.
Thank You!
Paul 'W' U.K.
27helpful
2answers
Engine code P0505 for 2002 honda odyssey
p0505 is directly related to the idle air control valve (sometimes called the rotary valve) i cant count how many of these i have replaced on hondas. It is located directly under the throttle body so it can be difficult to replace. I would recommend you having a professional replace this due to the difficulty of the valve removal
4helpful
2answers
Blown fuse
go here this should help
2002 honda odyssey
let me know how you do and if you need more info
later paul
Top Honda Car Audio & Video Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Honda Car Audio and Video Expert? Answer questions, earn points and help others
